will f550 outer monobeam knuckle
thedieselkid
westva
fit on a d60? im planning to convert my f550 to 4x4. i got a d60 axle. thought everything was the same except for brakes but i was not correct. the mounts for the f550 caliper bracket bolts are shorter hole to hole.
so im asking if anyone knows if the 2wd outer knuckle will work on 4x4 d60 axle.??
tia
u2slow
bilge rat
Coastal BC
I believe 2wd and 4wd match for a given year.
99-04 the inner C dimensions are the same F250-F550.
2005+ the balljoint spacing changes... F250/350 is bigger, F450/550 is bigger again.
ntjapkes
