What waste oil makes the best fuel
Kiwif150
Waimate New Zealand
Doesn’t the psd have electric pump n DI heads?
Frame mounted electric pump up to and through the fuel filter bowl , electrically switched unit injectors driven by a mechanically driven high pressure oil supply pump ... up to 21000psi fuel injection pressure
And this is fine on WMO?
The old idi's run the fuel at 1800psi. You need that high pressure to turn the fuel into a fog so it burns properly. All diesels run the fuel at a high pressure, so all of them have some sort of high pressure pump system, either seperate or built into the injection pump.
Alleycat
