Diesel JD
I found one of these in the junkyard as well guys, don't know if it still has what is needed or what the owner would charge. How big of a PITA is the job? Thanks
JD
JD
You have a '90, the pedal brackets and stuff changed in '92 IIRC, so if it works for you it should work for JD as a bolt-in as well. Then again Gary has an '89 that is the same setup as yours and JD's, and he swapped pedals... I dunno, but you can always do like me and stack a few washers between the booster and the firewall on the bottom set of studs, this will tilt the whole booster back and make the rod sit more straight without having to move the pedal pin higher. Your brake pedal will sit about 1/2" lower, but most folks complain how high the pedal is anyways. If studs in the hydroboost ain't long enough then punch them out and use 3/8" Grade-8 bolts with nuts on the other side, this is how I did mine cause the Chevy pushrod was so much longer than the Ford one.I didnt use the stock assembly from the truck my booster came out of. Just put it in and bolted it up. Is it because of the body style he has?
