What´s wrong- NO it´s not the obvious! Smokes like hell!
derjackistweg
Cologne/Germany
3pin connector is the block heater unit. the wire plugs into the pins.
the "stream" ....... you mean vapors/smoke?
Block heater, alright. Did ford charge the style of the connector?
With steam I mean "smoke"- thought of its water it's by definition steam not smoke anyway.
derjackistweg
Cologne/Germany
the "smoke" you see is blowby....ie compression getting through the rings.
As mentioned above - it´s not that easy. Compression is like on a new engine (cold). "Smoke" is pretty much sure not oil - so probably water.
But look at the cap: no emulsion on that - what would be typical for a water/oil mixture! Engine has been run since install roughly 5 hours or more.
Smoke from the exhaust is constant. So with higher RPM it is still there. There is no "if you let the pedal-off" more smoke coming like (at least) I would expect from bad valve guides.
Next steps in a intelligent way are required. My truck sits 200 miles away !!! btw.
- how to check if valve guides are the source of the BLUE smoke out of the exhaust? The easy way ???
- Any suggestions on how to remove the IP from a VAN?
is that vid shot at idle of off idle? only way to properly tell blowby is raising the rpms about 300-500 over idle.
derjackistweg
Cologne/Germany
The video above with the smoke coming out of the Oil Filler is in idle. With RPM rising there is nothing.
This is NOT my truck - but looks similar. Here it was the IP:
if you have no blowby off idle you have no issues.
stop imaging problems where there's none :D
now the white smoke on the exhaust is a very real problem.
i do need to confirm you aren't seeing this in the wintertime right?
you have seen this in the summer?
derjackistweg
Cologne/Germany
smoke in the exhaust is blue, not white. You are probably right regarding the white smoke from the oil filler- no issue there.
today I removed the IP from the van. not a fun job! I needed to undo all 8 lines at BOTH ends to get it out! ☹ no way to get them between the Fuek Filter and Tranny oil check line.
but its out now and will be checked .... to be continued.
derjackistweg
Cologne/Germany
Pump is out now. I spoke to someone who has knowledge :Thumbs Up [I mean in Germany with knowlege]
Just by talking about some issues on the engine he pointed out that the "advaning whatever piston below the pump thing" [I don´t have the correct working in engl. at the moment cookoo] is probably stuck. Having a short look at that: He was right!
http://www.derjackistweg.de/wp-content/uploads/2017/01/IMG_20170222_163117-e1487777748226.jpg
So that´s I am after now. to be continued ...
derjackistweg
Cologne/Germany
Update:
After installing the partly rebuild IP, I was able to get the truck started. Due to an unknown issue with a non working starter I needed to jump the relay with a cable to “S“ terminal @ the starter solenoid.
If anyone has an idea what this is it's very welcome. Starter, solenoid and starter relay (ex changed) do work.
Back to main topic:
In the first 30 seconds the engine was not working on all 8 - add you can hear and see. This is due to air in line #2. This line was also not totally right and fuel leaking. No biggy anymore ...
ntjapkes
