Transmission Issue
92chevyidi
st pete florida
I have a 92 chevy k1500 with the 6.2. Has an odd problem on what I think is a 700r4. It will stay in first until about 2500 rpm then shift straigt to what seems like 3rd gear since the converter will lock a few seconds after and thats as far as it will go, no 4th. If I put the shifter in 2nd it just stays in first and if I let it coast down to around 30 and ease into the throttle it feels like it is in neutural. The fluid is allitle dark and does not smell burnt and it does not slip in 1st 3rd or reverse. Thanks for any help
lindstromjd
Black Sheep
West Des Moines, IA
From what I recall of the way a 700 works, 1 and 3 are on the same clutch packs and 2 and 4 are on the same. If yours doesn't shift 2nd or 4th, I'd think that your problem would be there. Probably rebuild time.
BrannonB
