The "Spot The Problem" Thread
FordGuy100
Silverton, OR
So I had to move the truck down to our new home about 200 miles away. The last time it was really driven was when I drove from Tx to Or after it had sat for 3 years. It has sat for about 3 years this time too. I did drive to town a few times in those 3 years, but nothing far.
I bled injectors, started it up, loaded with most of my shop stuff, and headed out. Hazed for about 15 minutes then cleared up. Ran great.
FordGuy100
Silverton, OR
Yeah that was an interesting development. I got onto I5, put the tach to 2500-2600 RPM's and let it rip. I guess the tach bounces a few hundred RPM's cause my wife told me I was cruising 75-85 mph. It used some fuel.
david85
Campbell River, B.C.
When I first put my truck back together and went for a spin, it was not happy. Struggled to accelerate and lots of smoke. It took a good 15 minutes before it started feeling normal again. All the gauges worked except for temperature...I should probably look into that hehe.
FordGuy100
Silverton, OR
Missing a factory tach is more of an option based problem lol.
I was talking about the speedo not working at all. As you can see, less then half the gauges actually work. It is what it is
Your speedo is cable driven, the internal cable is probable broken.
Thewespaul
Bulverde, Texas
Okay now spot the problem here LOL
Passenger and driver side front:
Appears passenger tire is straight, drivers is turned out left a bit.
Or are the center cabs covering the locking hubs?
Thewespaul
Bulverde, Texas
Getting close! It does seem like it's closer but the wheels are actually straight and aligned...
ntjapkes
