Finally got around to tearing down an engine I got earlier this year. It will be going to scrap soon. Heads I assume are worthless as new castings are available, glow plug broke off in each. I removed the precups as I notice people are looking for them from time to time. Pulled the cam as I may use the gear on my 6.9 if it has the old style, and the cam can be a good core for whatever grind I get eventually. Anything is the bottom end worth pulling out to hang on to or sell? Have the balancer, front cover, pulleys, etc off the front that I can clean up and use on mine or sell. This engine had water in several cylinders and is seized. Crank and rods may be serviceable, but are they in demand at all? Thought about pulling the piston cooling jets, not sure if there's any value or if they're still available new? Bellhousing adapter plate on the back worth anything? Want to clear out space but just don't want to scrap anything that is NLA and may be in demand.
