Probably 3rd low range. That's what I pulled with when 4.10'd 4 spd, but I didn't have 35's, was running just under 32's, so that might make you want to pull in second. I'd try a couple dry runs (no sled) and see how it gets rolling in either gear, maybe even try 2nd high range. Mine seemed soft in 3rd low but once moving worked really well, it got rolling, then started to come up on RPM's just as it needed to as wheel spin was less of an issue.
Good luck and have fun!
