85rollback
1986 idi. Great running motor. Left the key on and drained the batteries over two weeks. I mean DRAINED two brand new 900 cca batts. Now the fuel shutoff solenoid clicks like it's working, but not getting fuel to the tops of the injectors and the motor cranks great but no start. Fuel lift pump works great and getting good fuel at the top of the fuel filter right before the injection pump. I have not opened up the top of the injector pump. Could the solenoid have burned up? Thanks for reading. EDIT: FSS is working properly. The fuel shutoff valve in the bowl seems a little sluggish though. I would expect it to be free moving. I did prop the fss open on the inside per jesus freak and made sure the plunger was back, but still no fuel to the injectors. Could I have gummed up the top of my injection pump? I turkey basted out the bowl and filled with atf thinking if i then moved the plunger back and forth it would free somethin up.. Is it just gravity from the bowl to feed the pump? I don't want to take apart the pump, but if that's what I need to do I will.
