New kickers for the old 1986 F350 + build info
Rusgo
US
Studs and brake rod all welded up. Using the original brake rod end plus 1.2" to get the right length and fitment.
Welded both side of the studs and filled in the old holes because OCD
Have some big pipe from an old aircraft hanger that looked about the right size for a hydroboost nut socket. Notched a 1 7/8" square using a straight edge and eyeball
Sent from my SM-G975U using Tapatalk
Rusgo
US
Rough piece fit perfect on the first try. Should have just left it there, grabbed a pipe wrench, and torqued it off
Instead I spent a couple hours welding all the grooves, added a piece of square tube in the back for any wrench, and shaped it meticulously...
End result is the best fitting, prettiest, most durable hydroboost socket out there [emoji23]
Rusgo
US
All bolted up! Pedal is in a good spot. looks so much prettier than the vacuum can.
Test fitting the lines. Bought them for the late 90s trucks with hydroboost. The steering pump lines look different.
One has an oring and the other a white plastic washer. Anybody dealt with this before?
Thinking I might have to get the right adapter for the pump reservoir
Rusgo
US
I had an extra pump with a different adapter in my garage. The new power steering line threads into both but the end doesn't contact the base of either
I'm thinking it's only the small Teflon washer that forms the seal.
chillman88
Central NY
That would be my guess. There's probably o rings in the fitting itself so the hose can still turn even when the fitting is tight. I wouldn't be afraid to try it but I'd have some oil dry just in case!
Rusgo
US
Yeah so nomatter what line fitting is in the reservoir this new style line will work. The Teflon seal just crushes itself when installed and the line pivots on the internal orings even when tight.
Probably a single use deal
Rusgo
US
Fabbed a bracket to mount a proportioning valve/distribution block to the master cylinder
I get a kick out of making anything. Like holy crap, that just came out of a hunk of metal..
Had to weld in a little brake fitting to plug a sensor hole on the master cylinder
And going to epoxy in a barbed fitting into the fill neck of the in the steering pump reservoir for the hydroboost return line. Hopefully epoxy can stand up to brake fluid [emoji28]
TNBrett
Middle Tennessee
Don’t put brake fluid in your power steering reservoir then, and everything should be fine.
Sorry, I couldn’t resist.
That bracket looks nice BTW. Should be a nice setup.
Rusgo
US
Haha, definitely solid advice. I could edit the post to correct, but it should stay up
Rusgo
US
Rear brakes finished up. Took so much time. Always underestimating how much time this stuff takes
Clean and strip and etch and clean and paint. Oof
Feels dirty putting Cadillac parts on here, but I have a truck with the same brake setup so parts are easy
Reversed the factory Ebrake cable and with small modifications it worked perfect for the caliper Ebrake brackets
They need more slack though. When installing super duty springs will integrate Ebrake bracket into forward spring hanger, setting it further back
Wondering if I should ditch the factory brake lever thing attached to the axle and body? Looks like it adjusts brake pressure depending on ride height changes
Rusgo
US
Prepping stuff and doggo keeping company
chillman88
Central NY
Yes. They're known to fail and start leaking at some point and as far as I know no longer available. I would remove it from the equation if it was me.
Rusgo
US
Hydroboost install finished. Entire brake system is new. Better be just pads for the next decade!
Really like how the distribution block install looks. Custom and unique. Easy access to control pressure to the rear brakes
Power steering lines turned out super clean. Lots of bending to make make it look factory
