Meyers snow plow guys look here
Dieselcrawler
Professional wrench holder
Staff member
Quakertown Pa
Any of you guys running the Meyers ez classic tube mount plows on your 80-91 f250-350 trucks? I need a photo of how the kicker brace is. I have the main mount in, but the kickers won't line up with anything. I looked up the diagram, it appears part 4-5 in this photo is what I need pictures of.
Ok, I have a Meyers but I made my own mount, I never used the one above. I did notice most of the factory Meyers snow plow mounts move the bumper forward ahead of the plow assembly. Looking at it, I am going to guess piece 4-5 is a piece to remount the bumper. If you look at the bottom of piece 4-5, it mounts to the side of the plow mount assembly. Then it sticks up forward in the air, and looks an awful lot like the original bumper mounting setup.
Dieselcrawler
Staff member
Quakertown Pa
That's on the regular mounts. The ez mount my does not touch the bumper. That's why I wanted this one, no hairlip.
Here are the Meyer instructions for that diagram you have above.
http://www.storksplows.com/docs/wp-...-Ford-F250-F350-truck-Meyer-classic-mount.pdf
Reading the instructions what I get out of it, you are correct the bumper stays put. You take the bumper bolts out though(one side at a time so it doesn't fall off I suppose) and the top part of 4-5 goes into the "C" of the frame at the bumper bolt to frame location, and new bolts are added to bolt the bumper and bracket 4-5 onto the truck inside each frame rail. The lower end of 4-5 bolts to the side of the big mount unit as it shows in the picture.
Dieselcrawler
Staff member
Quakertown Pa
Yea I saw that. The kickers I have look nothing like them. Hoping for some clear photos of the proper bar so I can remake them
