I pulled my old mechanical pump out because I had air intrusion and was thinking I would go electric. It was in working condition when removed about a year ago.
Now that my air intrusion issue is solved I've decided I will go mechanical with electric in parallel for priming only, eg hooked to IP high idle circuit, and as an emergency backup.
My fear with mechanical pumps is dumping fuel into the engine if the diaphragm fails. I've had this happen on another engine with a cheap lift pump. So I'm wary of the cheap pumps on amazon, etc.
My old pump is at least 24 years old and has been removed for over a year. So I really don't trust that diaphragm either.
I'm wondering if anyone has repaired/rebuilt one of these pumps and if there is a kit for it. Or has a recommendation for a quality pump.
I also found a NOS motorcraft pump on ebay that I'm considering, but I don't know how old it is either. Probably much newer than mine.
