Lots of blue smoke
fordf350man
Rockwood MI
Its been a long time since I have posted on here since I sold my idi, nice to be back.
Ok so I currently have a 1997 7.3 powerstroke that is blowing out blue smoke pretty heavy at first start up then it settles down. It still smokes a little, but is clear that it is blue. When I give it throttle is starts pouring out blue smoke again. Now I thought maybe the turbo was in need of a rebuild, but I just went out and checked the end play on the shaft and I am not getting really any movement in or out or up and down. The shaft seems to be ok. So I took off the intake manifold after the turbo and there was some oil in the turbo but did not seem like enough to cause this much smoke. So I left the intake manifold off and started the engine and it still smoked like crazy on start up then cleared up. So i shut it off again and then it did the same thing. So I am pretty sure the turbo is not my problem.
Now the engine runs great, no missing, runs smooth and no loss of power, no oil in coolant or coolant in oil, no fuel in coolant and no oil in fuel. I am not sure what would be causing this at this time. I am thinking maybe injector o rings? or maybe head gaskets? I am not sure. Any help would be appreciated.
Just a little history on the truck, I bought it from a friend, he bought it from a landscaping company. Only has 155,000 miles on the truck. He drove the truck and on the way to his cousins house it died. He said the fuel tank and filter were nasty and gummed up and there was water in the tank also. He cleaned everything and could not get it so start. He is not a mechanically inclined person so he sold it because it was just sitting for about 4 to 5 months in his driveway and his wife was pissed about it. I bought it, and after replacing the IPR, IDM, and some rotted fuel lines the truck fired right up and runs like a champ. Just have this smoking issue now.
fordf350man
Rockwood MI
I haven't had the truck out on the road yet to determine that, it needs tires really bad, and i don't have it plated, i wanted to get it running first, only driving i have done is down the road and back, but the oil level is good
This isn't oil.
People really need to stop trying to compare gassers to diesels. It's apples to oranges.
Check all of your glowplugs. And the harness pins.
I know I have At least 1 bad pin at the UVCH connector. I get a tiny bit of blue smoke on a colder startup. Guess how much oil I use over 10k miles?....
fordf350man
Rockwood MI
I know it is not a gasser, but this isn't a little bit of blue smoke, it pours out when it first starts like oil is settling down in the cylinder, then after running for a minute it starts to clear, but it is still blue, give it throttle and it starts pouring out again, can that harness cause that much smoke? I'll try to see if i can get a video of it or at least a picture of the smoke
I don't know about anyone else, but I know if I got a stick that's not firing.
heres a way to test it without disturbing the harnesses.
fordf350man
Rockwood MI
This is the tuck after running for about ten minutes with throttle
This one is at first start up
This is just idling after about 8 minutes of running
honestly if you intend this vehicle to be daily driven, I would start by draining the tank, checking the sender and the pick up and put fresh fuel in it.
nothing like replacing everything to find out you have chitty fuel.
fordf350man
Rockwood MI
I have already done that, i did put one quart of transfluid in the tank and some in the fuel filter when i replaced it, but i don't think it would smoke like that from just transfluid
crazier things have happened. sounds like you just need to put some shoes on it and run it....
ive always been told after the ATF trick, you run it like you stole it
no mufflers
rhode island
not the same issue, I had a customers truck (97 PSD) that took forever to start. he only used it in his yard a little but it mostly sat. when I was finished with it he was able to drive it on the road and it began to start like normal again. he uses it like a real truck too, WFO.:peelout
I'm a little confused. Your Sig say's it's a 97 7.3 NON TURBO, yet you say you checked the turbo for play.
There is no manifold on a 97 that you could take off and leave off, unless your talking about the AIR INTAKE.
As far as the fuel in the tank, unless you've drained it and put in fresh fuel, you don't know what's in there. could have a lot of oil of some kind, maybe even some lousy reclaimed oil in there.
The fuel does not go thru the turbo to the cylinders. a small amount of oil in there would be natural, most of the oil would be burn't causing the smoking. There's no way for oil to get into the turbo other than the oil supplied to it for lubrication.
now im confused. by intake, I read it as the Y that goes from the turbo to the plentums, pull this off and its running N/A
on the driverside valve cover, is that not a new style CDR? its plumbed into the air intake...
Yeah, forgot about that. Pretty hard to get a lot of oil thru it the way there constructed, but could be if the guts where removed.
