Not sure of the other 2, but even into the 6.0 trucks..... Ford still loves to use vacuum. They have gone to hydroboost 4 wheel disk brakes (Thank God in a 7000+lb Excursion), but I have a nice little electric vacuum pump mounted to the passenger inner fender about the size of a shoebox. This still runs the HVAC Doors, and it operates the vacuum pulse ESOF front hubs. That is all it does. It in NO WAY HAS THE ABILITY TO RUN VACUUM BRAKES!!! Just wanted to make the clear in case someone thought they could "upgrade" to an electric off a SuperDuty truck and still run the old vacuum brakes. If you swap to the F-Superduty Hydroboost, you could get away with an electric vacuum pump, or a marginal mechanical vacuum pump.......
So in short so no one gets hurt....
Hydroboost brakes + Electric Vacuum Pump = Good
Vacuum brakes + Electric Vacuum Pump = NO POWER BRAKES or BAD!!!!!!
