divemaster5734
The last axle conversion kit is due to ship. Am using Sky Offroad RS front and rear conversions.
Those will take '08-'16 SD leaf springs.
I will be adding bags in the rear, but probably not for several months.
My quandary is deciding which springs are best.
I realize the more leafs means higher rating, but also means worse ride when empty.
I'm guessing the Bronco clip and two bench seats might add 500lbs. to the stock F350 weight.
The 3 or 4 leaf sets are a better ride, but much lower rating.
That said, a soft ride equals mushy turning.
I drive mostly winding mountain or rural roads, and don't want to create a pig in turns to get best straight line ride.
I know there's several people here that have already crossed this bridge and am hoping for some insight and possible lessons learned.
Just like a modern vehicles ECU, there's no one setting that's perfect for everything, so I'm hoping for better turning without needing a kidney belt to drive it.
It won't be towing anything until next spring, and I'll have the bags installed by then.
All I have is theory to go on, hoping for some real life examples.
Thanks.
Thanks.
