Into the depth of the cowl...
1mouse3
il
The floor pan had to be patched in this truck, and was told water can come the cowl area. I see there is signs water is still getting in, the floor mat is still rolled up.
This is what I found looking in the cowl area...
Here, its cleaned up some and will replace the sealer that was there...
My suspect of the leak would be here and will see what I can do with it. Any buddy here found isses to note with this voild that have been found?
1mouse3
il
I had all ready brushed it some to get some the large chunk out and treated it with acid...
I found these hose picks to try some more...
They do well to get the old sealent out...
Some scrub pads and grease remover help with the rest...
So is now cleaned up a fair bit...
Even got most removed from the driver side piller, this was a bit challenging...
On the passenger side, I only delt with the top part and rest will be dealt with at latter date
That hole is the hvac box and have time before it gets cold...
This crevice had sealer injected from the inside and I will be trying to inject from the outside, picked out as much as could...
This all would be easier with scaffolding but all I have is a rudimentary step stool, to be able to step up on to the tires.
rreegg
Puget Sound
Cheers man, pulling off old sealant is so annoying but really satisfying when done - there's a lot on there and in a small space.
Curious what sort of product will go on to replace
1mouse3
il
Ok, Iv cleaned this twice and did not git it done before the bad clouds pass...
So another round of scrubing the phosphate acid in, then sanding in the cleaner, and followed by wipeing off with the cleaner.
Well, a finger to the sky and shooting the primer anyways, after wipeing with the acid. Not sure if will hold up, but might make it easyer next time. Now its going to be cold and going to need a industrial size hair drier, to lay the sealant when I see this again.
I even tried to get down here with the raddle can.
@rreegg this is what I am going to use, when I can get around weather.
Yea, those hold the cowl panel down. I dont think there big enogh to do anything to the tire, think found a bigger one in the tire before.
Dang. I found one in my tow trucks dual while I was pulling the wheel lift, it's holding air though........I'm still good.
ROCK HARVEY
Dayton OH
I’m patching my floor pans right now and I found water leaking in through my cowl as well. Looks like I’ll be tackling this next! You should also check the seam sealer in your drip rails, I guarantee it’s cracked too and letting water drip down inside your A and B pillars.
1mouse3
il
Yea that is a issue as well but there other more important stuff on the list of stuff to do, so will be some other time.
To make you feel better, they have been reduced in full to the safest place that they wont get lost.
1mouse3
il
Well time has come again to try again at cleaning this cowl up, but at least I layed primer to cut down on clean up time.
Found more body damage when cleaning...
It gose with this and the bent up core supprt...
Ehter way got a new coat of primer layed and got to finger painting sealent...
The last of the tube was injected into both these corner...
Then the engine enamel piant that shot too thin to do any real good, but at least there may be something.
