IDI Front wheel drive trike
So after a few bevvies last night sitting in doorway of the cube van....a fart of brain came upon me like a man wailing on a railway spike with a hammer.
See me feet sitting there...
K so the fart of brain.....
Get a steering column...and a 4wd F150 Chassis...use a Bronco Tcase...fixed output shaft no slip yoke.
Drive front axle...add a seat over trans...saddle tank for fuel...and somehow a single rear coaster wheel
Making a trike with an IDI either C6 or E4OD rat rod type delio
Drunkin brain farts...
Whos in?
Thanks for looking.
BDCarrillo
Abilene TX
Pull the axle shaft out of a sterling rear, lop the last few inches off the tube before the hub, and there's your coaster wheel with brake.
AAAALLLLL....... Ya gotta stop drinken that "stuff":eek::eek:;Really:rolleyes::D:sly:angel::thumbsup:
I would do it but sure would die testing the top end speed on it... Wonder if Bonneville would allow or have a class for this...:dunno
Kizer
Denton, Texas
I like the way you think! I'd consider the "go cart" option though..keep it RWD..maybe DRW?
compressionignitionrules
Bluevale ON
I just sold my 88 E250 Quigley 4wd van chassis. would have been perfect for the job but would have lifted the chassis a good 4 inches.
you have to be carefull with ideas like that. they can cost a lot of time and money;Sweet
Clearly.......ya dont know me.....***** falls in me lap...this idea is badazz but probably simple if enough parts fall my way....
Just sauin...
you can use the rear output shaft of the transfer to a modified turbo for moar boost! and keep it spooled even inbetween shifts.
