HOW DID FORD SECURE THEIR CAB-SIDE EMBLEMS to the BODY??
satx78247
san antonio, tx
Friends,
I've found a NOS "Lariat" emblem for the one on my cab that's missing on the 1986..
It has two pins on the back but no obvious (at least to me) method of securing it to the side of the Super-cab.
(I'm considering something like "liquid nails" but am not at all sure if that's a good idea.)
You advice is solicited.
yours, satx
laserjock
Almost there...
I use 3m double sided automotive mounting tape. Pins are for location only.
satx78247
san antonio, tx
laserjock,
THANKS, Partner. ======> ORDERED.
(I'm going to get the '86 returned to factory stock, yet.)
yours, satx
Clb
Another old truck
nannyfornia
The old trucks used a little rectangle of tin with a small hole in the middle and 2 c shaped reliefs to grip the pin.
satx78247
san antonio, tx
Clb,
I suspected that that might be the case. - That technique however I won't even try, as I would have to remove about half of the Super-Cab's interior appointments to do it that way.
As I said above, I'm going to try the double-sided tape to hold the little emblem on.
THANKS, satx
ironworker40
NYC Ironworker
nj
Clb
Another old truck
nannyfornia
Thanks... Been decades since I worked with the body shop.
I like the glue and pal nuts idea.
Stacx
What no take the whole truck cab off to get to the rear head bolts for you?-cuss
Another engineering crowning moment!
Waystro
No Class
South Texas
On my 86 when I debadged it all emblems had a rubber glue on it I'm not so sure double sided tape is the best thing I haven't had very good luck with it in the past. Interested to see how it works for you guys.
If you go to AutoZone they have the emblem glue as they call it. I like the debadged look for myself so never really worried about it. :dunno
catbird7
PA
X2 on the 3M double sided tape.
Double sided tape. There is nothing like the tape used for laying carpet (joining the edges together). once you stick something together it's all Hell to get it off. It's expensive for a 25 ft roll. If you know a carpet installer, just get a small piece from them. It's 4" wide. That's what I use. I know a carpet installer uses a hot iron to melt the glue on it, but it's not necessary.
crash-harris
Breaker! Breaker!
Chillicothe, OH
The parts stores sell what was basically used from the factory. Emblems were backed from the factory with a die-cut foam, double adhesive backing. Always remove the old dry foam adhesive before applying new stuff. Autozone sells a roll that's the perfect width for our trim badges (under the F-***). You'd just have to lay a few strips on the F badge and trace it with a hobby razor.
ntjapkes
