help with kent moore j33300 and 7.3 timing
Foreste2002
Prescott, AZ
Hi…i purchased a used J33300. It came with the piezo clamp, the 5/16 ********* flexible wand and a larger probe with an optical eye ( i think)
My timing cover only has the lower larger bung which is slightly smaller than the larger optical eye probe.
Should i try enlarging the bung to fit this?
Otherwise i will buy another timing cover with both bungs
thanks
Eric
Clb
Another old truck
nannyfornia
Optical eye?
Do you mean
Luminosity probe?
Go's into a glowplug hole.
Don't mod stuff yet...
Foreste2002
Prescott, AZ
there are a number of threads on this meter, and how to use it.
I have not used one of these units.
Foreste2002
Prescott, AZ
Thanks…I had read I think all of posts I could find about using the machine. I just have not found someone using the larger port on the harmonic balancer plate with the larger fitting that I posted a picture of.
