having trouble with fuel fitting
Goose_ss4
ca
the fitting going into the I.P. from lift pump. thinking of switching to electric, but can't get the right inlet fitting. I think it is a flare o-ring , and I am trying to go to npt. does anybody know it or have done the same thing as me? please help
johneich
John, 1983 F250
Southern Illinois
On my truck the filter is in between the lift pump, yours should be the same, so you would have a lift pump to filter line and then a filter to IP line.
My answer would be the same though: put a short piece of rubber fuel hose on the flare steel line, clamp it tight with a hose clamp and get your npt fitting with a hose barb, clamp the short fuel hose to the barb and you are done.
Here are some pics of how it worked for Jonathan and I:
http://www.oilburners.net/forums/showthread.php?t=47528
Goose_ss4
ca
I move my filter under the bed. I have a better quality house that I want to install, but held up by fitting.
basilbowman
Sewanee, TN
I did the same thing when I couldn't get an olive for the steel line - works fine so far. I used hydraulic hose instead of fuel line, thought it might stand up to WVO a little better.
typ4
Newberg,OR
it is a -5 o-ring boss thread easy to get at a hyd shop
