carid
Supporting Vendor
Looking for the perfect running boards for your truck or SUV? We’ve got you covered with a range of options from AMP Research, designed to give you both style and convenience. The PowerStep Xtreme is built for tough conditions. It extends when you open your door and tucks away when you close it, keeping things sleek. With a tough surface for grip and weather resistance, it’s ready for mud, snow, and everything in between.
If you’re all about the latest tech, check out the PowerStep Smart Series. These boards deploy automatically with wireless technology, making access easier without you lifting a finger. Plus, they come with built-in LED lights, so you’re always stepping safely, even at night.
Got a lifted truck? The PowerStep XL is just what you need. It offers a wider step and drops lower, so getting in and out of your vehicle is a breeze. Like all AMP Research boards, it’s durable, weather-resistant, and gives you the convenience of automatic retraction. Perfect for anyone who wants a rugged yet refined look.
AMP Research® - 6" PowerStep Xtreme™ Black Running Boards
6" PowerStep Xtreme™ Black Running Boards by AMP Research®. At CARiD.com you can find a comprehensive line of AMP Research replacement and performance parts and accessories which ensure reliability and superior performance.
www.carid.com
Note: Choose your specific model in "Product Options"
Features:
- PowerStep Running Boards produced by AMP Research are original factory equipment on some vehicles
- Running boards extend outward when doors are opened, then retract flush underneath the vehicle when doors are closed
- Ideal for off-roading where traditional fixed-in-place running boards may become damaged due to ground clearance issues
- Running boards are triggered automatically when any door on the corresponding side is opened or closed
- Sealed power motors mount directly onto the folding linkage assemblies with ease
- Running boards extend and retract in approximately one second
- Safe for young children because pinch protection sensors will reverse the direction of the boards if resistance is detected
- Each side is rated to support 600 pounds
- LED Lights illuminate boards when deployed
- Comes with a controller module which you can mount under the hood and wires directly to your battery
- Aggressive design for extreme traction, all-weather performance made from high-strength, die-cast aluminum components and maintenance-free, self-lubricating bushings
- Bushings are sealed for protection against grit and the elements and require no lubrication
- Legendary reliability with durable, high-texture powder-coat finish to resist corrosion and maximize grip
- Precision stainless-steel pivot pins for rock-solid stability, OEM-quality motors, drive system, and wiring harness that set the industry standard
- Warranty: 5 years / 60,000 miles
- Manufactured in the United States
AMP Research® - PowerStep Smart Series Black Running Boards
PowerStep Smart Series Black Running Boards by AMP Research®, 1 Pair. With OBD Connector.
www.carid.com
Features:
- No need to install manual override switch. In App Override Switch upgrades the Powerstep system to allow in-app manual override of the deploying steps and LED lights.
- Profile has been developed to complement and flow with the chiseled design of new body style trucks.
- Low Profile LED kit includes an auxiliary port to power and operate additional LED lights.
- Apps available for both IOS and Android.
AMP Research® - 6.25" PowerStep™ Black Running Boards
6.25" PowerStep™ Black Running Boards by AMP Research®. Take the time to look through our extensive collection of AMP Research products that can help you to get the most out of your truck, car, or SUV.
www.carid.com
Features:
- Ideal for off-roading or other use where traditional fixed-in-place running boards may become damaged due to ground clearance issues
- Safe for young children because pinch protection sensors will reverse direction of the boards if resistance is detected
- Each side is rated to support 300 pounds
- Comes with a controller module which mounts under hood and wires directly to your battery
- Bushings are sealed for protection against grit and the elements, and require no lubrication
- Die-cast aluminum construction and stainless steel pivot pins ensure a lifetime of freedom from corrosion
- Running board surfaces feature a powder coated finish that effectively resists scratches, chips, and discoloration
- Warranty: 5-years / 60,000 miles
AMP Research® - 6.25" PowerStep XL™ Black Running Boards
6.25" PowerStep XL™ Black Running Boards by AMP Research®, 1 Pair. Take the time to look through our extensive collection of AMP Research products that can help you to get the most out of your truck, car, or SUV.
www.carid.com
Features:
- Add wow factor to your truck with AMP Research PowerStep XL™ Running Boards
- 3" lower stepping surface than the regular PowerStep™
- Automatic power-deploying running boards
- Running boards extend and retract in less than a second
- Low-profile integrated LED light system – standard
- Attractive and durable black wrinkle coat finish that effectively resists scratches, chips, and discoloration
- Textured back step for maximum traction
- Step, die-cast aluminum-alloy components with an anodized and pre-coated, military-spec finish to resist corrosion
- Precision stainless steel pivot pins for rock solid stability
- Fully welded/integrated bracket system supports up to 600 lbs
- Weatherproof, OEM-quality electric motors, drive system and wiring harness
- Maintenance-free, self-lubricating bushing for all-weather performance
- Great for lifted trucks
- Warranty: 5 Years / 60,000 miles
You can browse the full catalog of AMP Research products on our website:
AMP Research™ | Power Side Steps, Running Boards, Bed Extenders - CARiD.com
Get more use from your pickup with AMP Research accessories. Haul lengthy cargo with a bed extender and get in and out easily with side steps or running boards.
www.carid.com
