Found On Road Dead
HEAD HUNTER
Designated Decoy
Clear Cutting America's Forests
I have a 96 (company truck) totally stock. It wouldn't start, keep in mind my diesel mech. has only worked on old diesels and new cat and cummins. None of use have experience with a powerstroke. replaced glow plug relay, truck is fine for 3 days. On the 4th day it died on the way home. 5 minutes later it fired up and ran fine the rest of the way. Fuel filter is fresh, fuel is clean and fresh. What could cause this? Now is the time to fix things. We are probably snowed out for a awhile now. Got about 2 feet of snow over the weekend.
Mastertech
Car Doc
Houston
Sounds like you may have a Cam Position Sensor going bad.
When it dies and you crank it over does the tach show any RPM's ?
HEAD HUNTER
Designated Decoy
I ran it down to the international shop this morning and it had thorwn a p0344 code. CPS it is. Bought a new one for $95. It's not in yet though.
Thanks for the help boys.
oh yeah its a 97, not a 96, my bad. I never drive it.
Mastertech
Car Doc
Houston
Headhunter
That CPS is held in buy a bolt with a 10MM head that is tight as HELL so make sure you use a good 6 point 10MM socket on it or you may round off the head of the bolt.
This is assuming that the CPS has never been taken out before.
HEAD HUNTER
Designated Decoy
Originally posted by Jefe-Rat
Headhunter
Your tellin me. SOB that bolt was tight. Smashed 2 knuckles on the water pump too, once I chisled enough mud off it to find it. But it is all over now. Truck runs fine so far.
Thanks again
Wideopen
It's all about me.
TS Perfomance Baby!!
Thanks again
How about that someone found there Ford Diesel Problem without consulting " The Diesel Stop":D
CHarlan
Bulverde TX
All that for the CPS?? What a pain. I am not familiar with the Ford Diesel, but 2 busted knuckles would have my temper through the roof! Cheers to ya!
ntjapkes
