For Sale Gear Vendors Overdrive
Status
Not open for further replies.
dieseltruck
Frederick, Maryland
I removed it from my 89 F250 4x4, when I converted it the truck from a C6 to a E4od.
Pick up only. $1,500
Farmer Rock
Glen Rock,PA
can you split gears with it, or is it just an overdrive? I'm not very familiar with these.
I'm only 30 minutes away or so.
Thanks
Rock
Go to Gearvendor web site, and there is a lot of info on them.
That looks just like the one I pulled from a 89 F-250 with a C6 in Oct. First I have ever come across in a JY.
Farmer Rock, you can use a 2 spd shift switch for a 2 spd axle on your shift lever.
Or with an auto, there is a Dimmer switch you can use.
Lots of YT vid on guys shifting them. Cool little unit.
Would this work for a 4WD T19?
This unit was on a C6 trans.
I pulled one off a wreck that was connected to a C6.
I want to install on my T-19 2 wheel drive.
You will need to purchase the correct Adapter for your transmission.
Called GV, guy said I could send in mine for a core, and purchase the new one....seems like the guy said $700.
There are used adapters that come up on CL etc... every once in a while.
parkergn
Toronto
Hi! Is the GV overdrive still for sale? Looking to install on my E350 6.9 IDI, with a C6 trans. Thinks it’ll work?
Where are you located, I’m up in Toronto.
Black dawg
sw mt
This was in a 4x4, correct? From the op, looks like this was bolted to a c6/1356 combo, meaning it bolts to the 1356 transfer case.
Status
