Electric pump recommendation for 6.5l??
homelessduck
I do not have room for a mechanical lift pump so I need an electric one. I read somewhere, can't find it now... that the 1993 pump was the best, is this true?
I just need a dependable unit that won't starve it, nothing fancy. Google is always good, but I prefer your opinions :D
http://www.ssdieselsupply.com/p37_6.5_td_supplylift_pump.html ?
homelessduck
Mucho thanks Calvin ! So this pump should work? It's hard to believe so for $30!
have you seen how far GM necks down the pipe right before the pump? iirc it's like a 1/4" hole.
so yes. that pump should be enough.
ntjapkes
