E4od idi
Bsthomas21
Gold hill North Carolina
Just bought a 93 f250 7.3 idi n/a having a issue where sometimes the truck will shift on its own like normal and sometimes I have to manually shift it because it will try and start out in 3 or O/D. The O/D light never flashes any help would be awesome !
yARIC008
Drives really slow
Orlando, FL
I literally just went through something similar. Truck was actually in fourth, not third. It ended up being the MPLS. The computer couldn’t tell the lever was in drive do didn’t send grounds to the two shift solenoids to shift into the other gears while in drive. You can take the MLPS off pretty easy and test the resistances to see if the resistors or traces have failed.
trackspeeder
Stone crusher.
North Branford. CT
Scan it for codes. It might have something stored.
Culprits for this. Transmission Range Sensor (MLPS), VSS, Tach, or TPS.
Alleycat
