That's gotta be one of the most annoying $5 repair jobs ever. My driver's door same story, but I'm not sure I'm dedicated enough to fix it. Super annoying when I'm loading 3 of my kiddos + stuff into the back seat though...LMC has them for $4.95. Dorman has a replacement spring too.
That's a fact!That's gotta be one of the most annoying $5 repair jobs ever.
I removed the door and was able to remove the upper and lower hinges easy enough. The real frustration began when I put the door on and off about 10-15 times before I managed to get it hung correctly. I swore that if I ever had to replace hinges again that I'd remove the fender to hopefully make things easier.But to do that, the fender really needs to be
removed for access to the top Hinge.
