delphi injectors, two part numbers??
Black dawg
sw mt
Lately the local parts stores have been selling the delphi injectors, and list a different part number for the 93-94 turbo motor.
Any of you guys selling these injectors have any thoughts?
G codes were my thoughts too. Might ask and see what the counter person tells you.
Black dawg
sw mt
Well there are actually 3 different delphi part numbers.
6760301 84-92
ljck01102 93-4 turbo
ljck01101 92-4 no turbo BB code same part # as original Lucas?/cav BB codes used in these trucks
I am surprised that delphi would go to the trouble to make copys of the stanadyne injectors.
jhenegh
Truck Still Earns its Keep
Deerfield, WI
Rockauto price:
ljck01102 $55.79
ljck01101 $36.79
Amazon:
6760301 $30.86
ljck01102 $47.30
ljck01101 $40.76
19887.3IDI
Michigan
Was just doing some internet browsing and found this info not sure how accurate it is but I thought it was interesting...
LJCK01101 133-143 Bar pop pressure
LJCK01102 126-136 Bar pop pressure
6760301 126-134 Bar pop pressure
jhenegh
Deerfield, WI
Geez you'd think they could tighten up the specs a bit. 145psi range on the LJCK01101. 1930-2075psi
laserjock
Almost there...
That's why a matched set costs a little more. It takes effort to pop test and match them. You can just stab them in but it's bound to run smoother if they all pop at the same pressure. That's almost cheap enough that if I had a pop tester, I'd think about setting up a set myself just for grins.
ntjapkes
