Crawl mode lock out
1mouse3
il
Was needing a usable shifter for the bw 1345 that came with the t19 and this caught my eye. This would moves like a normal shifter, over the weight check of the aluminum ones.
This is the one that came with it...
I had to poke a hole for it and this one is in better placement with the old bar, so can make this work and have boot with cain. Issue is with the lock out plate, did this shifter ever come in a t19/bw1346 marriage for the bricks? Thinking to just run with out it and hold on to it till when ever I find a 460 zf.
1mouse3
il
I believe the style of shifter you have mounted was used on the 1356.
James
and a e40d...
I dug around seeing if can find any clues and found this, there is not a lot on the 1345 over the 1356 that seem to be more common. I found that there was two differrent adaptors used and I have the misfortune of having the first one.
adaptor 13-01-066-902
adaptor 1301-566-010
ntjapkes
