C3500HD Bed onto F450
A Mirage
Laguna Hills, Ca
Thinking of buying 2004 F450 only 89,000 miles to replace my 2000 C3500HD with 189,000 miles
Is it possible to put the Utility bed from the GMC on to the Ford.
The Ford has a 12' stake bed on it now and the GMC bed is 12'
Andertusa
S.W. Minnesota
It's all about the wheelbase and width of the truck. If you have decent metal fabrication skills, it could easily be modified to fit, either through adapters or what-have-you. Most 'aftermarket' flat-beds are sorta generic, and are often designed to fit an assortment of trucks, so you shouldn't have too much difficulty as long as the frame-mounts are similar, and the wheelbase of the truck's is the same, or more specifically, the distance from the rear of the cab to the axle centerline.
gavinc
