Brake problems
Randy Dechant
Keenesburg Coloraado
Hello. I have a 96 F350 7.3 2wd crew cab dually. I have replaced both front and rear brakes, Also replaced the master cylinder. I still have a pedal that goes to the floor when the truck is running. I am on the 3rd master cylinder and nothing has changed. Is it the power booster bad? I am out of ideas to fix it. I also bypassed the ABS valve. Need to get this fixed soon. Any help will be greatly appericated..
Clb
Another old truck
nannyfornia
11 Diesel Down!
Post New Thread
This is only to be used in an absolute emergency. If your truck is down and you need Assistance fast, this is the place for you.
^^^ Copied from the top of this section!
Now that That's outta the way and we see the cross post...
Try looking at...
Rear adj.
Booster
Pushrod
Air
Rabs
Warped rotors
4x4dave
Topock, AZ
I had that problem with my 84 i want through 4 remanufactured masters, if is sits to long pedal goes to the floor for a couple pumps, if i adjust rear brakes up almost tight, (with a good drag) it takes care of the problem, hope that helps.
