barely any heat in cab, seems radiator/water pump below temp as well?
snicklas
6.0 and Loving It!!
Staff member
Greenfield, Indiana
CaptTom
ca
Aluminum is very conductive. Lol
Basically you add a ground to the heater core.
:***:Did I write!!! LOLLOLLOLLOL What a maroon!! Sheesh.
Because it is so well insulated, how is it corroding through the fresh water circuit? It's totally surrounded by rubber, plastic or foam, and attached to rubber!!
There... that's what I was thinking.... I thought.... sheeeesh.... obviously the coffee hadn't kicked in yet, and stupid was at full throttle!!!!
Will solder on one of my "aluminum" eyelettes, and run a ground wire. I still can't believe I said that in public.... :frustrate:frustrate:rotflmao
Thewespaul
Bulverde, Texas
Read up on this thread, it’ll make you fell better about that mistake!
https://www.oilburners.net/posts/924571/
CaptTom
ca
LOLLOLLOL
Thanx for the moral support!!!
I'm gunna drive my burner home now, and open some bourbon.... I might just smell it, don't wanna risk another ridiculous post in the same day!! :fan::joker:
Have a great weekend!!!!
snicklas
6.0 and Loving It!!
Staff member
Greenfield, Indiana
Capt,
The electrical current is in the coolant, so in this case, all the rubber hoses don't matter.
I've seen a test with a digital meter, where you put one probe tip in the coolant and touch the other tip to the battery negative, and you can measure several millivolts between the two.
http://www.ve-labs.net/electrolysis-101/how-to-test
ntjapkes
