Any new fuel sending unit suppliers?
Clb
Another old truck
nannyfornia
Need a new front tank sender, rheostat **** the bed.
I have a bookmark for tristar in nyc,
Rebuilders.
Anything better from usa?
catbird7
PA
Both of the tanks in my truck have senders for gasoline fuel systems. I simply purchased without the intank fuel pump, and added a short piece of fuel line and strainer. Gas senders are inexpensive and readily available.
You are buying sending units for a 460 equipped truck I am assuming? Wondered if that would work. The wiring plug doesn't plug in does it?
zebrabeefj40
Pepperell MA
I purchased new diesel sending units from LMC Truck complete with a new showerhead. Of course they were $150/ea (twice the gas units...).
Nick
Farmer Rock
Glen Rock,PA
I think I saw them on JC Whitney and possibly Rock auto,although I question the quality of JC whitney these days.
Rock
Stu Bailey
Idaho
I have bought three different ones from these guys and all are working great.
https://www.ebay.com/itm/1987-1989-...ding-unit-for-the-Side-tank-ONLY/391267780476
I’ve been looking at these same units too. I’ve been running one tank for a year now and it’s only a matter of time until this one poops out as well. I haven’t heard anything bad about them, I’ll probably buy a new tank from them as well with tax return and finally get my front tank back up and running!
How long have they been running in the trucks Shadetree?
Clb
Another old truck
nannyfornia
Thanx gents, keep it coming...
The ole girl is inside the warm garage waiting.
Btw
The trex website don't list a 93 but like 3 90-91 , betting it's a typo...
My kid gave me a tip, I'll pass along...
To access the senders, pull all 3 driver mounting bolts and loosen up the pass. Side lift drivers side up and block.
(fangers crossed fer you rustbelters)
Btw
Yea, instead of unbolting the bed you usually have to grind the bolt heads off. And then sawzall the rest of it off underneath.
i buy these. isspro or summit. ~120
comes in a variety of lengths, and ohm sweep.
Randy Bush
Great Falls, Mt
I find the front one fairly easy to pull. Drop driveline. And can get right to it. Front tank, rear is different story.
Sent from my SM-A115A using Tapatalk
