After market Tach and Stock sensor
J.P.
Yucca Valley/Ca./USA
Does anyone know if there is a after market tach that will work with a stock Ip cover sensor on a 1994 7.3 IDI, there is a 2 wire connector on it with a 2 pin plug?
J.P.
I thought I would pull this one up again and see what hits, I did search the site and did not come up with much, so does anyone know if there is a after market Tach that will work with a stock sensor???
rhkcommander
Oregon
There are aftermarket tachometer kits but IDK of any that use the stock device, I figure there could be. if i recall proper the 2-wired sensor is magnetic and counts the teeth to send a signal...
I know dakota digital had some LED panel with all the gauges on it including tach, someone on here has one but I cant recall who :dunno
looks like this one might work, came up for v8 diesel... but when i look for engine specific nothing comes up:dunno
http://www.summitracing.com/parts/SWW-82620/
less likely
http://www.summitracing.com/parts/SWW-82621/
http://www.summitracing.com/parts/SWW-82636/
might be cheaper/easier to just get one with the crank pulley & magnet, or one of them alternators that outputs rpms :dunno
Alleycat
