6-71 inline gov issues
rjjp
Needs to go test
Clare, Mi
Also cyl kits and rings are diff.........besides some sort of throttle delay/modulator etc
Is this stuff really necessary though? I mean like the IDIT had bigger wrist pins, and a better oil cooler, and bigger main webs, but it wasn't necessary.
geonc
SPIDER BAIT
NECKVILLE North Carolina
With respective compression ratios of around 23:1 na and 18:1 turbo.....a few factors come into play...
1- being weather it has trunk style [one piece] pistons or cross head [separate crown/skirt]
2- keystone fire ring[top ring of 3 comp rings]
3- liner ports
4-steallite exh valves
5-the above mentioned blower seals so all the boost doesn't find it's way into the crankcase = not good!
6- a modulated fuel rack to prevent dumping a ton of fuel without the boost pressure to condense it...in other words a sort of time delay till boost pressure can burn the delivered fuel...
There are a few other items but you get the idea...
NOW---can it be done ...SURE just toss a turbo on and go....Question is will what is in there hold it?????
DeepRoots
Tug Engineer
Douglas, Georgia
I recall the NA vs Turbo'd Detroit compression was 16:1 vs 15:1 maybe I'm wrong tho but it isn't nearly as severe as 23:1 vs 18:1
course in the end it is all about what level a particular engine is being built for, I like going heavy on everything because broken parts suck :p
geonc
SPIDER BAIT
Whoopsie!!! my mistake....been messing and talking about these Navistars more in the past years ...
Anywho...right from the field service data book..
Old style comp ratio of 17:1 New N series 18.5:1New Style turbo 17:1.
DeepRoots
Tug Engineer
Douglas, Georgia
yeah, dont' have my books on me, I knew it was only a point or so tho.
I have to wonder how a NA direct injection engine would run with 23-1 compression.
rjjp
Needs to go test
Clare, Mi
It would probably be quite efficient.
Alleycat
