10.25 LSD rebuild
laserjock
Almost there...
Contemplating rebuilding the LS in Big Red. I know it’s worn out. Might as well be an open diff. I looked up a couple threads. It seems very similar to the 8.8 I did in my half ton a few years back less the ******* spring clip that damn near killed me when it flew out. No c clips because it’s floating axle. Roll the spider gears out swap in new clutch disks and roll them back in. Am I missing anything?
laserjock
Almost there...
Carrier shouldnt have to come out I don’t think.
laserjock
Almost there...
In a related matter, does anyone but Yukon make these anymore? Best I’ve found is 144$ through amazon so far.
laserjock
Almost there...
USA standard gear has two part numbers/options for clutch kits
USA16155
USA16011
I think the second one is correct. Rock auto has them both listed. About the same price as the Yukon set.
Thewespaul
Bulverde, Texas
That’s where I got them, 16011 crosses over to the Yukon kit so that’s gotta be the right one. $144 sounds like a pretty decent price
laserjock
Almost there...
So looks like the Yukon set from Amazon is a reasonable choice then.
laserjock
Almost there...
Yessir. Don’t forget to soak the clutches in gear oil before install, helps them last longer
Yup. I don’t know if I’m going to get to this soon or not. Probably would be good if I can. My spring mountains trip goes over some pretty steep gravelish road. With the camper on there it can get hairy. Rather not have to run with the hubs in through there if I don’t have to.
chillman88
Central NY
Just bring them with ya and we'll change them at the rally :D
no mufflers
rhode island
Detroit locker... problem solved ;Poke.
i had mine rebuilt and it works ok in perfectly even terrain. like dirt and snow if its the same on both tires itl work. ice and snow yer stuck fer sure. take a turn in the rain and give it the go juice yer one tire peeling outta there.
i know there expensive but worth the money and i think we all know when you get stuck its never text book. with a Detroit if one tire is on ice and one on dry pavement you can still pull the trailer.
