Snowturtle
Actually, new everything! I was planning to replace my 120k mile IP with a slightly upgraded one from Classic Diesel due to black smoke, high EGT's, and I was having a hard time getting the timing right and then the truck died, wasn't getting any fuel. So, I took that as my sign to get to work. I bought new everything: 90cc injection pump, lift pump, injectors, return lines, fuel filter, glow plugs, glow plug solenoid. I figured it was easiest to access all that stuff while I had it apart. All back together now and I'm not getting fuel at the injectors. I am getting fuel out of the bleed valve on the filter. Have I missed something? Was it possible to put the pump in wrong? 180 degrees out on the timing or something? Or does it just take longer than I expect to work fuel through the system? I didn't want to keep cranking in case that's ******* the dry injection pump. I guess my next thing is to loosen the fuel supply line at the IP to see if I have fuel there. I can continue on with basic checks, just wanted to check with more experienced people to see if there is something glaring that I may have missed or done wrong. I replaced the IP once before about 12 years ago and don't remember having any problems - but that was a long time ago and my brain is much older now!
Also, I replaced the glow plug solenoid because I was not getting the clicking anymore after the wait to start light goes off. New glow plugs and new solenoid and still no clicking. Light stays on 20-30 seconds, but no clicking after it goes off. Do I need to replace the rest of the GP controller?
Thanks in advance for any help!
