I'll probably start mine today because I need to use the crane (electric)...so I'll watch it closer than usual and report back.
My oil line is plumbed into the block near the oil filter...so...it should be pretty quick...and...I started it two days ago to use the crane then, too...so...the crank time should be pretty short.
According to my guage...(not sure what brand but it looks pretty decent) I usually hit a shade over 40 PSI and it stays there...I don't remember what the pressure may have dropped to burning hot at idle...(been a while since I towed with it) but nothing alarmed me...and yes, I was looking at the guage pretty regular...
I have 15W40 in it right now(probably the best 'budget' oil I could get at (shudder) ...---mart)...and a decent brand oil filter from rock auto...either wix or FoMoCo...original style...
And...if I can get a filter with an anti-drainback valve...I will use it because I want it...not because I don't 'need' it...
This is America...and it is not a question of 'need'...
Update; Warm this morning and engine fired up immediately...
Oil pressure guage needle started moving during "One Mississippi..."
It does not 'pop' to 40+ PSI...more like "Hey, Hey, Hey...Outta My Way..."
Stayed at 40+ the whole time it was running to warm up....
I am sure that there is air in the line...I never bled the air out when I snugged the ferrule up to keep it from leaking...
That is the way it always has been and the engine runs fine...no smoke and exhaust note seems ok.
I should check the timing...I'll get to it...
