What radiator and hoses are you guys using
Austincarnut
austin
What radiator and hoses are you guys using for 97 dodge 2500 cummins engine in OBS ford diesel crew cab? do you buys have pics / numbers? I noticed the OBS ford can have very different water outlets depending on year / model
u2slow
bilge rat
Coastal BC
You can change the upper water neck on the Cummins to suit your rad. 89-91 (non-intercooled) is pass side hookup.
If you want a dodge rad, I recommend the 94+ style due to cooling capacity and cost. The 1stgen one is smaller and expensive. The last one I put in my truck was a Spectra-Premium from rockauto.
