what is this wire called on the Water in Fuel sensor? Part #?
92LongBed
Spartanburg
I am tracking a fuel leak/air intrusion and my half cocked water in fuel sensor wire finally broke off completely. Anyone know a part number or actual name to order a new one or do I need to get lucky in a junkyard?
Thanks folks
Reggie f250
Bartlett il
That is for the fuel filter light. It is a pressure sensor for when the filter gets clogged.
92LongBed
Spartanburg
if this water in fuel sensor cable is off or broken, can air get into the filter housing? my schrader valve only pulses fuel it does not give me a 100% stream of fuel but my truck runs very well sitting still, had it stall on me after driving for 1-3mins after finally getting it running again due to air intrusion and replacing bad FSV
92LongBed
Spartanburg
Sounds like your fuel pump is getting weak or it is pulling in air from somewhere
yeah i went scouring for the new spot and i think this is what my issue is, going to throw a new fuel line hose on it tomorrow, currently have diesel kleen sitting in my injection pump just to make sure its not a sticky injector causing some fuel starvation. will test the pump for PSI
720Diesel
Staff online
