Transfer case fluid change advice please.....
Diesel D
Kaukauna WI
Changing the transfer case fluid in my '02 F-350 7.3L 4x4. My truck has the dash switch/solenoid selector as opposed to the manual floor shift lever. Any suggestions for which fluid to use?
u2slow
bilge rat
Coastal BC
It will literally work on any thinner oil that the pump can circulate. I recommend the same as the trans because seals can let go and the fluid transfers from one to the other.
Rdnck84_03
Kansas
I have always run dex3/mercon. Which should be the same thing the 4r100 or zf6 calls for.
James
