Tow/haul mode
If your tow/haul mode quits working or is intermittent, pull the rubber boot thing at the base of the shifter and find the orange wire. At the clip holding it give it a little tug. Most likely you will pull it in half because it sits right at the tilt joint and takes a lot of abuse. Just strip it and reconnect the inner white wires. Also would be good to add in some wire to keep from recurrence. Then yay you're done and it works again.
The only one I've seen and fixed was a 2002. Unfortunately I'm not around a lot of Chevy's anymore. But apparently it's pretty common. Just shifting bends and rubs the wire against the metal clip. Plus add in a tilt wheel and it wears faster. But I'm sure all 2000 and up.
ntjapkes
