THE PARTS BIN
Status
Not open for further replies.
Moderator's note: Use your browsers "find" function to help locate parts by name.
Also... An extensive list of part numbers for PSD trucks, some of which cross over for us can be found HERE and should be checked if you don't find what your looking for in this listing.
Tired of blank looks when dropping by the stealership for a posteior massage? here's a few parts numbers, description(in parenthesis the real name) and year range for fitment. Will add as list grows. BTW, "all years"='81 to '94.
4/19/05
*** All are Ford Part numbers ***
E3TZ-6A665-A "Adapter assembly for Crankcase Ventilation" Also known as the CDR (Crankcase Depression Regulator) Valve ALL YEARS
F1TZ-9A758-E CABLE ASY(THROTTLE CABLE) ALL YEARS
E7TZ-7515-A LEVER(CLUTCH FORK) ALL YEARS
E5TZ-17B384-A TACH SENSOR ASY ALL YEARS
F5TZ-7277-A BOOT(SHIFT BOOT) ALL ZF5 TRANS
F3TZ-2C342-A BUSHING KIT(CLUTCH PEDAL) 92-94
F4TZ-8678-A IDLER ASY 92-94
F4PE-19E708-AA BRACKET(DRV SIDE ASY) 92-94(updated design)
F4TZ-6B209-A TENSIONER 92-94(updated design)
F3TA-2L487-BB PULLEY(VAC PUMP) 92-94
E7TZ-7207-A GASKET(TRANS SHIFTER COVER) ALL ZF5 TRANS
E7TZ-7262-A RETAINER(TRANS SHIFTER COVER) ALL ZF5 TRANS
E69Z-7526_A BUSHING (Pedal arm to clutch master cyl rod)87-94
F1TZ-7548-B Greaseable Throw Out Beaing Assy (includes hose)t-19 only
E3TZ-6A636-H Oil Cooler Gasket Forward head
E3TZ-6A636-G Oil Cooler Gasket Rear head
E3TZ-6A008-A Head to Deck Mating Pins (All Years)
E5LY-3A697-A Reservoir w/attg. parts(P/S pump res. F450)89-94
E5DZ-3A697-A Reservoir w/attg. parts(P/S pump res. kit F250/350 all years)
E1AZ-3B584-A Seal and gasket kit(P/S pump complete reseal kit)
F4TZ-1504366A BRKT1/PNL TO CW (repair braket to correct 92 and up dash droop)
E8TZ-6A892-A Retainer (grommet for lower tube to valley pan) Also used with 088 turbo pedestal.
E3TZ-6A892-A Retainer (grommet that connects cdr to intake)
WPT-165 1U2Z-14S411-AAA wiring pigtail kit List price of $50.82. (used to replace burned up headlight switch connectors on 92 and up OBS, possibly earlier)
E9TZ-3E715-B 'acutator' - the pot metal piece that breaks in the steering column.
7.3 Bullet style glow plugs are ZD9
6.9 Spade style glow plugs are ZD-1A
Firewall Clutch reinforcing kit big plate, E3TZ7K509B about $126.90
Firewall Clutch reinforcing small kit(E3TZ7K509A)is only $16.25
F7TZ-3E651AA - Steering Damper Kit (Field Fix Kit) studs
E7TZ-3E651B - Steering Damper Kit (Field Fix Kit) eyelets
8C3Z-4033-A - Alluminum Finned Rear Differential Cover (intended for 08-2010 Superduty, but fits all Sterling 10.25 from 86-2010. You will need new bolts)
F2TZ-9B989-C - Throttle Position Sensor for E4OD transmission (Early Black FIPL has High Failure Rate. RECOMMENDATION Always replace the black colored early FIPL or any colored FIPL having 60 thousand or more miles with the late gray colored FIPL)
***International Part Numbers***
Thermostat with gasket 1807974C94
Oil Cooler thicker ring 1804414C1
Oil Cooler thinner ring 1807563C1
Fuel Line 5/16 Olive 1815780C1
Fuel Line 3/8 Olive 1878937C91
***Gale Banks Part Numbers***
PN 94042-00 IP gear cover adaptor, for making a road draft tube.
Update 6/2/05
Editors note: Frank (Soulpatch) adds...
I can only tell you that the following parts were purchased for my 92 250 2wd 7.3 n/a LWB (S-cab with AC)...
if you want/need better descriptions or anything else, let me know.
Frank
Motorcraft:
IFS right axle mounting bracket - F4TZ 3B178 A
vacuum pump - F3TZ 2A451 A
tensioner (open spring) - F2TZ 6B209 D (early design)
serpintine belt - JK61113A
rear U joints (x2) - F3TZ - 4635 A
carrier bearing - E4TZ 4800 A
thermostat (with gasket) - E5TZ 8575 C
radiator cap - E5TZ 8575 C
clutch/brake pedal assembly - F3TZ 2455 A
snap-in plastic bushing only (for above) - E69Z 7526 A
tailgate latches (pair) - E8TZ 99431D76 B and E8TZ 99431D77 B
***NAPA Part Numbers***
Fuel Filter with water seperator and drain for 7.3L head (no sensor) - FIL3417
water pump - 125 5018
thermostat gasket - C-24551
thermostat 385-190
upper rad hose - 8411
lower rad hose - 8103
tensioner (open spring) - 38123 (early design)
serpentine belt - 25 061110
air filter - 6255
CORK valve cover gasket - VS39311
Coolant filter remote mount #4019 (is a mount kit that includes a filter head, mounting bolts and hose fittings)
There are a number of choices for filters. If you want a filter with no coolant additives, the #s are 4069, 4070, 4083 or 4084
If you want coolant additive built into the filter, I recommend # 4071 (4 units).
***Baldwin Part Numbers***
BF1222 Fuel Filter for 7.3 without Sensor Port
BF1222-sp Fuel Filter for 7.3 WITH Sensor Port (direct OEM replacement)
***WIX Part Numbers***
these fuel filter part numbers are the latest bottom cap delete filters.
33417 - Fuel Filter for 7.3 without Sensor Port
33617 - Feul Filter for 7.3 with sensor port
***ARP Head Studs and Associated items***
Studs - AR7.00-LB
Washers - ARW78N
Nuts - ARN12-1
***VARIOUS Manufactures Parts***
Edelman - p/s pump to hydro - 71415 (f450 88-94)
Edelman - hydro to gear- 71416 (f450 88-94)
Modine - 3 row radiator - 2194
Interstate - battery pos cable - SF 0115
Felpro - valve cover gaskets - VS50247R
Fumoto - drain valve - F107* (*comment from Mike...Fumoto recommends part number F-111 for 7.3L diesels from 95 up. Part number F-101 for other diesels. This is the part DIS sent me for my '91.)
Autozone - zd9 glowplugs - 004456 zd9
Lund - Visor mounting kit Part N0. series 1200-1900 Universal Kit #41103
Car Quest - Chevy Intake Gasket (for our air intake hat mounting surface) G 27098
*****motormite/doorman*****
MTM 6042344 OR DOR 42344 drainback pedestal grommet for ATS 088 & 093 turbos
DOORMAN 34184 AC delete pulley bracket
MTM 82582 power steering res cap
DOR 77177 right side interior door release handle
DOR 77178 left side interior door release handle
DOR 76946 window crank handle
LUK 07-065 which is the 12 inch T-19 upgrade clutch for our trucks. Cost is 160 bucks and has a lifetime warranty.
Gear Vendors Libricants
Mopar 04874459 Synthetic Change at 15K
GM 12346190 Synthetic Change at 15K
GM 1052271 Mineral Change at 10K.
McMaster Carr Viton products
Part No. 9464K24 - Viton O-rings for 6.9/7.3 IDI Injectors
Part No. 5119K13 FIRM Black Viton Hose for the hoses between injectors
Part No. 5119K861 FIRM Green Viton Hose for the hoses between injectors
Part No. 5119K864 FIRM Brown Viton Hose for the hoses between injectors Part No. 5119K43 SOFT Black Viton Hose for the hoses between injectors
Part No. 5119K21 FIRM Black Viton Hose for the hoses from the fuel tank to fuel pump & to the return line on the back of the engine {5119K891 = Green. 5119K894 = Brown)
Part No. 5119K51 SOFT Black Viton Hose for the hoses from the fuel tank to fuel pump & to the return line on the back of the engine.
If you didn't find it here, check this site also... http://www.intellidog.com/dieselmann/idiparts.htm
The Old Bull Collection (the following list was compiled by Oldbull8. Many Thanks. Ed.)
Navistar IDI & IDIT 6.9L/7.3L
IH Part number followed by Ford Part number
Block Components
Ford E & F Series
N 1 RVE5TZ6010EJ E5TZ6010E 1983-87 Block, Mains, 6.9L, E & F Series, Naturally AsPIRATED
N 1 RVE8TZ6010AJ E8TZ6010A 1988-94 Block, Mains, 7.3L, E & F Series, Naturally Aspirated
N 1 RVF3TZ6010BJ F3TZ6010B 1993-94 Block, Mains, 7.3L, F Series, Turbo
N 20 RVE3TZ6345AJ E3TZ6345A 1983-94 Bolt, Main, 6.9L/7.3L, E & F Series,
N 1 RVE3TZ6020AJ E3TZ6020A 1983-94 Gasket, Front Cover, 6.9L/7.3L, E & F Series, Naturally AspiraTED
N 1 RVF4TZ6020AJ F4TZ6020A 1993-94 Gasket, Front Cover, 7.3L, F Series, Turbo
N 1 RVE3TZ6D0833AJ E3TZ6D0833A 1983-94 Gasket, Rear Plate, 6.9L/7.3L, E & F Series, All
N 1 RV3110010J 3110010 1983-94 Heater, Block, 6.9L/7.3L, E & F Series, All
N 1 RVE3TZ6B070BJ E3TZ6B070B 1983-94 Plate, Front, 6.9L/7.3L, E & F Series, All
N 1 RVE3TZ6C330AJ E3TZ6C330A 1983-94 Plate, Lifter Retainer, 6.9L/7.3L, E & F Series, All
N 1 RVE3TZ6L080AJ E3TZ6L080A 1983-94 Plate, Rear, 6.9L/7.3L, E & F Series, All
N 8 RVE3TZ6C329AJ E3TZ6C329A 1983-94 Retainer, Lifter Clip, 6.9L/7.3L, E & F Series, All
N 1 RVE3TZ6700AJ E3TZ6700A 1983-94 Seal, Front Cover, 6.9L/7.3L, E & F Series, All
N 1 RVF2TZ6701AJ F2TZ6701A 1983-94 Sleeve, Rear Seal, 6.9L/7.3L, E & F Series, All
N 1 RVE3TZ6345BJ E3TZ6345B 1983-94 Stud, Main Bolt, 6.9L/7.3L, E & F Series, All
N 8 RVE5TZ6C327CJ E5TZ6C327C 1983-94 Tube, Piston Cooling, 6.9L/7.3L, E & F Series, All
Camshaft & Components
Ford E & F Series
N 1 RVE3TZ6250BJ E3TZ6250B 1983-94 Camshaft, 6.9L/7.3L, E & F Series, All
N 5 RVF4TZ6A251AJ F4TZ6A251A 1983-94 Bearing, Cam, 6.9L/7.3L, E & F Series, All
N 1 RVE3TZ6K252AJ E3TZ6K252A 1983-94 Bolt, Cam Gear, 6.9L/7.3L, E & F Series, All
N 1 RVE3TZ6287AJ E3TZ6287A 1983-94 Eccentric, Cam Gear, 6.9L/7.3L, E & F Series, All
N 1 RVF4TZ6256AJ F4TZ6256A 1983-94 Gear, Camshaft, 6.9L/7.3L, E & F Series, All
N 1 RVE3TZ6500AJ E3TZ6500A 1983-94 Lifter, 6.9L/7.3L, E & F Series, All
N 1 RVE3TZ6565AJ E3TZ6565A 1983-94 Pushrod, 6.9L/7.3L, E & F Series, All
N 1 RVE3TZ6265AJ E3TZ6265A 1983-94 Spacer, Cam Gear, 6.9L/7.3L, E & F Series, All
N 1 RVE4TZ6269AJ E4TZ6269A 1983-94 Thrust Plate, Cam, 6.9L/7.3L, E & F Series, All
N 1 RVE6TZ6278AJ E6TZ6278A 1983-94 Washer, Cam Gear, 6.9L/7.3L, E & F Series, All
Page 2 of 33
Crankshafts & Components
Ford E & F Series
N 1 RVE3TZ6303AJ E3TZ6303A 1983-94 Crankshaft, 6.9L/7.3L, E & F Series, All
N 4 RVE3TZ6333AJ E3TZ6333A 1983-94 Bearing, Crank, Std., Set of 4, 6.9L/7.3L,E & F Series, All
N 4 RVE3TZ6333BJ E3TZ6333B 1983-94 Bearing, Crank, .010, Set of 4, 6.9L/7.3L,E & F Series, All
N 4 RVE3TZ6333CJ E3TZ6333C 1983-94 Bearing, Crank, .020, Set of 4, 6.9L/7.3L, E & F Series, All
N 4 RVE3TZ6333DJ E3TZ6333D 1983-94 Bearing, Crank, .030, Set of 4, 6.9L/7.3L, E & F Series, All
N 1 RVE3TZ6337AJ E3TZ6337A 1983-94 Bearing, Thrust Std, 6.9L/7.3L, E & F Series, All
N 1 RVE3TZ6337BJ E3TZ6337B 1983-94 Bearing, Thrust, .010, 6.9L/7.3L, E & F Series, All
N 1 RVE3TZ6337CJ E3TZ6337C 1983-94 Bearing, Thrust, .020, 6.9L/7.3L, E & F Series, All
N 1 RVE3TZ6337DJ E3TZ6337D 1983-94 Bearing, Thrust, .030, 6.9L/7.3L, E & F Series, All
N 1 RV5871952J 5871952 1983-94 Bolt, Crankshaft, 6.9L/7.3L, E & F Series, All
N 1 RVE3TZ6316AJ E3TZ6316A 1983-87 Damper, 6.9L, E & F Series
N 1 RVE8TZ6316AJ E8TZ6316A 1987-93 Damper, 7.3L, E & F Series, Naturally Aspirated
N 1 RVF3TZ6316AJ F3TZ6316A 1993-94 Damper, 7.3L, F Series, Turbo
N 1 RVE3TZ6306AJ E3TZ6306A 1983-94 Gear, Crankshaft, 6.9L/7.3L, E & F Series, All
N 1 RVE3TZ6A312AJ E3TZ6A312A 1983-1993 Pulley, 6.9L/7.3L, E & F Series, Naturally Aspirated
N 1 RVF2TZ6A312BJ F2TZ6A312B 1993-94 Pulley, 7.3L, F Series, Turbo
N 1 RVE3TZ6B306AJ E3TZ6B306A 1983-94 Spacer, Crank Pulley, 6.9L/7.3L,E & F Series, All
N 1 RVE3TZ6332AJ E3TZ6332A 1983-94 Washer, Crankshaft, 6.9L/7.3L, E & F Series, All
Page 3 of 33
Ford E & F Series
CN 1 RVE4TZ6049EJ E4TZ6049E 1983-87 Head, Cylinder, Bare, 6.9L, E & F Series, Naturally Aspirated
CN 1 RVF0TZ6049HJ F0TZ6049H 1988-94 Head, Cylinder, Bare, 7.3L, E & F Series, Naturally Aspirated
CN 1 RVF3TZ6049JJ F3TZ6049J 1993-94 Head, Cylinder, Bare, 7.3L, F Series, Turbo
N 16 RVE3TZ6065AJ E3TZ6065A 1983-87 Bolt, Head, 6.9L, E & F Series All
N 16 RVE8TZ6065BJ E8TZ6065B 1988-94 Bolt, Head, 7.3L, E & F Series, All
N 8 RVE3TZ6K533AJ E3TZ6K533A 1983-94 Coil, Rotator, 6.9L/7.3L, E & F Series, All
N 1 RVF3TZ6582DJ F3TZ6582D 1993-94 Cover, Valve w PCV Mount, 7.3L, F Series, Turbo
N 1 RVE3TZ6582CJ E3TZ6582C 1983-94 Cover, Valve, 6.9L/7.3L, E & F Series, All
N 4 RVE8TZ6517AJ E8TZ6517A 1983-94 Deep Skirt Oil Shield/Exhaust, 6.9L/7.3L, E & F Series, All
N 1 RVE7TZ6051AJ E7TZ6051A 1983-87 Gasket, Head, 6.9L, E & F Series
N 1 RVE8TZ6051CJ E8TZ6051C 1998-94 Gasket, Head, 7.3L, E & F Series, Naturally Aspirated
N 1 RVF3TZ6051AJ F3TZ6051A 1993-94 Gasket, Head, 7.3L, F Series, Turbo
N 2 RVE3TZ6584FJ E3TZ6584F 1983-94 Gasket, Valve Cover, 6.9L/7.3L, E & F Series, All
N 8 RVE3TZ6510BJ E3TZ6510B 1983-94 Guide, Valve, 6.9L/7.3L, E & F Series, All
N 8 RVE3TZ6518AJ E3TZ6518A 1983-94 Keeper, Valve, 6.9L/7.3L, E & F Series, All
N 4 RVE7TZ6564BJ E7TZ6564B 1983-94 Lever, Rocker Arm, 6.9L/7.3L, E & F Series, All
N 4 RVE4TZ6057AJ E4TZ6057A 1983-87 Precup, 6.9L, E & F Series All
N 4 RVE8TZ6057AJ E8TZ6057A 1988-94 Precup, 7.3L, E & F Series, All
N 8 RVE3TZ6514AJ E3TZ6514A 1983-94 Retainer, 6.9L/7.3L, E & F Series, All
N 8 RVE3TZ6571A015J E3TZ6571A015 1983-94 Seal, Positive Valve .015 OS, 6.9L/7.3L, E & F Series, All
N 8 RVE3TZ6571AJ E3TZ6571A 1983-94 Seal, Positive Valve, 6.9L/7.3L, E & F Series, Naturally Aspirated
N 8 RVF4TZ6571AJ F4TZ6571A 1993-94 Seal, Positive Valve, 7.3L, F Series, Turbo
N 8 RVE4TZ6513CJ E4TZ6513C 1983-94 Spring, Valve, 6.9L/7.3L, E & F Series, All
N 4 RVE8TZ6505B015J E8TZ6505B015 1983-94 Valve, Exhaust, .015 OS, 6.9L/7.3L, E & F Series, Naturally Aspirated
N 4 RVF3TZ6505B015J F3TZ6505B015 1993-94 Valve, Exhaust, .015 OS, 7.3L, F Series, Turbo
N 4 RVE8TZ6505BJ E8TZ6505B 1983-94 Valve, Exhaust, Std., 6.9L/7.3L, E & F Series, Naturally Aspirated
N 4 RVF3TZ6505BJ F3TZ6505B 1993-94 Valve, Exhaust, Std., 7.3L, F Series, Turbo
N 4 RVE3TZ6507D015J E3TZ6507D015 1983-94 Valve, Intake, .015 OS, 6.9L/7.3L, E & F Series, All
N 4 RVE3TZ6507DJ E3TZ6507D 1983-94 Valve, Intake, Std., 6.9L/7.3L, E & F Series, All
Fuel Systems & Component Parts
Ford E & F Series
N 1 RVE8TZ9N653CJ E8TZ9N653C 1983-94 Clamp, 3 fuel lines, 6.9L/7.3L, E & F Series, All
N 1 RVE8TZ9N653AJ E8TZ9N653A 1983-94 Clamp, 4 fuel lines, 6.9L/7.3L, E & F Series, All
N 1 RVF2TZ12A342AJ F2TZ12A342A 1983-94 Glow plug, 6.9L/7.3L, E & F Series, All
N 1 RVE8TZ9E527AJ E8TZ9E527A 1983-92 Injector, 6.9L/7.3L, E & F Series, Naturally Aspirated, (V Belt)
N 1 RVF2TZ9E527AJ F2TZ9E527A 1992-93 Injector, 7.3L, E & F Series, Naturally Aspirated, (Serpentine Belt)
N 1 RVF3TZ9E527AJ F3TZ9E527A 1993-94 Injector, 7.3L, F Series, Turbo
N 1 RVE7TZ9A555AJ E7TZ9A555A 1983-94 Line, Fuel #1, 6.9L, E & F Series, 7.3L, E Series
N 1 RVE8TZ9A555AJ E8TZ9A555A 1988-94 Line, Fuel #1, 7.3L, F Series, All
N 1 RVE8TZ9A555BJ E8TZ9A555B 1983-94 Line, fuel #2, 6.9L/7.3L, E & F Series, All
N 1 RVE8TZ9A555CJ E8TZ9A555C 1983-94 Line, fuel #3, 6.9L/7.3L, E & F Series, All
N 1 RVE8TZ9A555JJ E8TZ9A555J 1983-94 Line, Fuel #4, 6.9L, E & F Series, 7.3L, F Series, All
N 1 RVE8TZ9A555DJ E8TZ9A555D 1988-94 Line, Fuel #4, 7.3L, E Series
N 1 RVE8TZ9A555EJ E8TZ9A555E 1983-94 Line, fuel #5, 6.9L/7.3L, E & F Series, All
N 1 RVE8TZ9A555FJ E8TZ9A555F 1983-94 Line, fuel #6, 6.9L/7.3L, E & F Series, All
N 1 RVE8TZ9A555GJ E8TZ9A555G 1983-94 Line, fuel #7, 6.9L/7.3L, E & F Series, All
N 1 RVE8TZ9A555HJ E8TZ9A555H 1983-94 Line, fuel #8, 6.9L/7.3L, E & F Series, All
N 1 RVE7TZ9A543AJ E7TZ9A543A 1983-87 Pump, Injection, 6.9L, E & F Series
N 1 RVFOTZ9A543CJ FOTZ9A543C 1987-92 Pump, Injection, 7.3L, E & F Series, Naturally Aspirated, (V Belt)
N 1 RVF2TZ9A543AJ F2TZ9A543A 1992-94 Pump, Injection, 7.3L, E & F Series, Naturally Aspirated,(Serpentine Belt)
N 1 RVF3TZ9A543BJ F3TZ9A543B 1993-94 Pump, Injection, 7.3L, F Series Turbo
N 1 RVF3TZ6K682AJ F3TZ6K682A 1993-94 Turbocharger, 7.3L, F Series
1. Fuel injection kit contains Injection pump and 8 injectors.
Page 5 of 8
Gasket Kits 1
All Applications
N 1 RV86069GKJ 1983-87 Kit, Gasket, 6.9L, All
N 1 RV86073GKJ 1988-94 Kit, Gasket, 7.3L, All Naturally Aspirated
N 1 RV86473GKJ 1993-94 Kit, Gasket, 7.3L, F Series, Turbo
Injection Housing Components
Ford E & F Series
N 1 RVE3TZ6766CJ E3TZ6766C 1983-94 Cap, Timing Housing, 6.9L/7.3L, E & F Series, All
N 1 RVE3TZ9A546CJ E3TZ9A546C 1983-94 Gear, Injection Pump, 6.9L/7.3L, E & F Series, All
N 1 RVE7TZ9C516AJ E7TZ9C516A 1983-87 Housing, Timing Gear, 6.9L, E & F Series
N 1 RVF0TZ9C516AJ F0TZ9C516A 1988-94 Housing, Timing Gear, 7.3L, E & F Series
Manifolds & Components
Ford E & F Series
N 1 RVE3TZ9C629AJ E3TZ9C629A 1983-94 Bolt, Intake Screen, 6.9L/7.3L, E & F Series, All
N 2 RVE3TZ9448AJ E3TZ9448A 1983-94 Gasket, Exhaust, 6.9L/7.3L, E & F Series, All
N 1 RVE9TZ9439AJ E9TZ9439A 1983-94 Gasket, Valley Pan, 6.9L/7.3L, E & F Series, All
N 1 RVE3TZ9431CJ E3TZ9431C 1983-94 Manifold, Exhaust, Left, 7.3L, E Series
N 1 RVE3TZ9431BJ E3TZ9431B 1983-94 Manifold, Exhaust, Left, 7.3L, F Series, All
N 1 RVE3TZ9430AJ E3TZ9430A 1983-94 Manifold, Exhaust, Right, 6.9L/7.3L, E & F Series, All
N 1 RVE5TZ9424DJ E5TZ9424D 1983-94 Manifold, Intake, 6.9L/7.3L, E & F Series, All
N 1 RVE3TZ9F460AJ E3TZ9F460A 1983-94 Screen, Intake, 6.9L/7.3L, E & F Series, All
N 1 RVE3TZ9B470AJ E3TZ9B470A 1983-94 Strap, 6.9L/7.3L, E & F Series, All
Page 6 of 33
Ford E & F Series
N 1 RVE3TZ6731AJ E3TZ6731A 1983-94 Filter, Oil, 6.9L/7.3L, E & F Series, All
N 1 RVE3TZ6A636CJ E3TZ6A636C 1983-94 Gasket, Oil Cooler, Header, Front, 6.9L/7.3L, E Series
N 1 RVE3TZ6A636GJ E3TZ6A636G 1983-94 Gasket, Oil Cooler, Header, Front, 6.9L/7.3L, F Series, All
N 1 RVE3TZ6A636HJ E3TZ6A636H 1983-94 Gasket, Oil Cooler, Header, Rear, 6.9L/7.3L, E & F Series, All
N 1 RVE4TZ6881AJ E4TZ6881A 1983-94 Header, Front, Oil Cooler, 6.9L/7.3L, E Series
N 1 RVE4TZ6881CJ E4TZ6881C 1983-94 Header, Front, Oil Cooler, 6.9L/7.3L, F Series, All
N 1 RVE4TZ6881DJ E4TZ6881D 1983-94 Header, Rear, Oil Cooler, 6.9L/7.3L, E Series
N 1 RVE4TZ6881BJ E4TZ6881B 1983-94 Header, Rear, Oil Cooler, 6.9L/7.3L, F Series, All
N 1 RVE4TZ6A642AJ E4TZ6A642A 1983-94 Oil Cooler Bundle, 6.9L/7.3L, E & F Series, All
N 2 RVE4TZ6K649BJ E4TZ6K649B 1983-94 O-ring, Oil Cooler End Caps, 6.9L/7.3L, E & F Series, All
N 2 RVE3TZ6C610AJ E3TZ6C610A 1983-94 O-ring, Oil Cooler, 6.9L/7.3L, E & F Series, All
Ford E & F Series
Oil Pan & Component Parts
N 1 RVE3TZ6675CJ E3TZ6675C 1983-94 Oil Pan, 6.9L/7.3L, E & F Series, All
N 1 RVE6UZ6750BJ E6UZ6750B 1983-87 Dipstick, 6.9L, E Series
N 1 RVE5TZ6750DJ E5TZ6750D 1983-87 Dipstick, 6.9L, F Series
N 1 RVE8UZ6750BJ E8UZ6750B 1988-94 Dipstick, 7.3L, E Series
N 1 RVF4TZ6750BJ F4TZ6750B 1988-94 Dipstick, 7.3L, F Series, All
N 1 RVE4TZ6730BJ E4TZ6730B 1983-94 Plug, Washer, Oil Pan, 6.9L/7.3L, E & F Series, All
N 1 RVE6UZ6754BJ E6UZ6754B 1983-87 Tube, Dipstick, 6.9L, E Series
N 1 RVE8TZ6754DJ E8TZ6754D 1983-94 Tube, Dipstick, 6.9L/7.3L, F Series, All
N 1 RVE8UZ6754AJ E8UZ6754A 1988-94 Tube, Dipstick, 7.3L, E Series
N 1 RVE3UZ6754CJ E3UZ6754C 1983-94 Tube, Dipstick, Lower, 6.9L/7.3L, E & F Series, All
Oil Pump & Component Parts
Ford E & F Series
N 1 RVE3TZ6600AJ E3TZ6600A 1983-94 Oil Pump, 6.9L/7.3L, E & F Series, All
N 1 RVE3TZ6626AJ E3TZ6626A 1983-94 Gasket, Oil Pump, 6.9L/7.3L, E & F Series, All
N 1 RVE3TZ6622BJ E3TZ6622B 1983-94 Tube, Oil Pick Up, 6.9L/7.3L, E & F Series, All
Page 7 of 33
Price
Pistons & Component Parts
Ford E & F Series
N 1 RVE4TZ6108GJ E4TZ6108G 1983-87 Piston, Std., 6.9L, E & F Series
N 1 RVE4TZ6108JJ E4TZ6108J 1983-87 Piston, .020, 6.9L, E & F Series
N 1 RVE4TZ6108KJ E4TZ6108K 1983-87 Piston, .030, 6.9L, E & F Series
N 1 RVE3TZ6148DAJ E3TZ6148DA 1983-87 Ring Set Std., 6.9L, E & F Series
N 1 RVE3TZ6148EAJ E3TZ6148EA 1983-87 Ring Set .010, 6.9L, E & F Series
N 1 RVE3TZ6148FAJ E3TZ6148FA 1983-87 Ring Set .020, 6.9L, E & F Series
N 1 RVE3TZ6148GAJ E3TZ6148GA 1983-87 Ring Set .030, 6.9L, E & F Series
N 2 RVE3TZ6140AJ E3TZ6140A 1983-87 Clip, Piston, 6.9L, E & F Series
N 1 RVE3TZ6531FJ E3TZ6531F 1983-87 Pin, Piston, 6.9L, E & F Series
N 1 RVE8TZ6102AJ E8TZ6102A 1988-93 Piston, Pin and Ring Set, Std., 7.3L, E & F Series, All
N 1 RVE8TZ6102CJ E8TZ6102C 1988-93 Piston, Pin and Ring Set .020, 7.3L, E & F Series, All
N 1 RVE8TZ6102DJ E8TZ6102D 1988-93 Piston, Pin and Ring Set .030, 7.3L, E & F Series, All
N 1 RVE3TZ6211AJ E3TZ6211A 1983-94 Bearing, Rod Std., 6.9L/7.3L, E & F Series, All
N 1 RVE3TZ6211BJ E3TZ6211B 1983-94 Bearing, Rod .010, 6.9L/7.3L, E & F Series, All
N 1 RVE3TZ6211CJ E3TZ6211C 1983-94 Bearing, Rod .020, 6.9L/7.3L, E & F Series, All
N 1 RVE3TZ6211DJ E3TZ6211D 1983-94 Bearing, Rod .030, 6.9L/7.3L, E & F Series, All
N 1 RVE3TZ6214AJ E3TZ6214A 1983-94 Bolt, Rod, 6.9L/7.3L, E & F Series, All
N 1 RVE9TZ6148EAJ E9TZ6148EA 1988-94 Ring Set Std., 7.3L, E & F Series, Naturally Aspirated
N 1 RVE9TZ6148GAJ E9TZ6148GA 1988-94 Ring Set .020, 7.3L, E & F Series, Naturally Aspirated
N 1 RVE9TZ6148HAJ E9TZ6148HA 1988-94 Ring Set .030, 7.3L, E & F Series, Naturally Aspirated
N 1 RVE3TZ6200CJ E3TZ6200C 1983-94 Rod, connecting, 6.9L/7.3L, E & F Series, Naturally Aspirated
N 1 RVF3TZ6600CJ F3TZ6600C 1993-94 Rod, connecting, 7.3L, F Series, Turbo
Page 8 of 33
Ford E & F Series
N 1 RVE8TZ6A892AJ E8TZ6A892A 1983-94 PCV Tube, 6.9L/7.3L, E & F Series, All
N 1 RVE3TZ6A892AJ E3TZ6A892A 1983-94 Grommet, PCV, 6.9L/7.3L, E & F Series, All
N 1 RVE3TZ6A665AJ E3TZ6A665A 1983-94 Valve, PCV, 6.9L/7.3L, E & F Series, All
International Truck
Ford E & F Series
Top End Component Parts
N 1 RVE3TZ9180CJ E3TZ9180C 1983-94 Bracket, Fuel Filter, 6.9L/7.3L, F Series, All
N 1 RVE9TZ9A335AJ E9TZ9A335A 1983-94 Bracket, Fuel, 6.9L/7.3L, F Series, All
N 1 RVE8TZ9A343AJ E8TZ9A343A 1983-94 Drain Bowl, Fuel Filter, 6.9L/7.3L, E & F Series, All
CN 1 RVE3TZ9155AJ E3TZ9155AJ 1983-87 Filter, Fuel, 6.9L, E & F Series, All
N 1 RVF4TZ9N184AJ F4TZ9N184A 1988-94 Filter, Fuel, 7.3L, E & F Series, All
N 1 RVF4TZ9417AJ F4TZ9417A 1983-94 Gasket, Fuel Lift Pump, 6.9L/7.3L, E & F Series, All
CN 1 RVF2TZ9B249AJ F2TZ9B249A 1983-94 Header, Fuel, 6.6L/7.3L, F Series, All
N 1 RVF3UZ9B249AJ F3UZ9B249A 1983-94 Header, Fuel, 6.9L/7.3L, E Series
N 1 RVF2TZ9J294AJ F2TZ9J294A 1983-94 Heater, Fuel, 6.9L/7.3L, E & F Series, All
N 1 RVF3TZ9F734AJ F3TZ9F734A 1983-94 Junction End, Fuel Return Line, 6.9L/7.3L, E & F Series, All
N 1 RVE5TZ9D308AJ E5TZ9D308A 1983-94 Line, Fuel Return , 6.9L/7.3L, E Series
N 1 RVE8TZ9D308BJ E8TZ9D308B 1983-94 Line, Fuel Return F, 6.9L/7.3L, F Series, All
N 1 RVE5UZ9L273AJ E5UZ9L273A 1983-94 Line, Fuel Supply, 6.9L/7.3L, E Series
N 1 RVE4TZ9P892AJ E4TZ9P892A 1983-94 Line, Fuel Supply, 6.9L/7.3L, F Series, All
N 1 RVE3TZ9350BJ E3TZ9350B 1983-94 Pump, Fuel Lift, 6.9L/7.3L, E & F Series, All
N 1 RVE5TZ8575CJ E5TZ8575C 1983-94 Thermostat, 6.9L/7.3L, E & F Series, All
Water Pumps & Component Parts
Ford E & F Series
N 1 RV8617WPK 2 1983-94 Water Pump Kit, 6.9L/7.3L, E & F Series, All
N 1 RVE9TZ8501BJ E9TZ8501B 1983-94 Water Pump, 6.9L/7.3L, E & F Series, All
N 1 RVE3TZ8507AJ E3TZ8507A 1983-94 Water Pump Gasket, 6.9L/7.3L, E & F Series, All
1. Piston Assembly kit contains (8) pistons, (8) pins, (16) clips, and (8) sets of rings.
2. Water Pump kit contains water pump and gasket.
Notes:
For F & E Series, complete VIN and serial number required to identify correct part number.
For International, serial number required to identify correct part number.
The engine serial number is located on a machined pad between the oil cooler and flywheel.
Status
SixFourShanks08
