Swap injector pumps.
Cranky
Apollo,pa.
Newbie here so bear with me.Own 89 f-450 7.3 n/a with poor power etc. 179,000 mi. Have 1990 donor truck with 60,000 original miles,it runs good.Question can I swap ip's. My truck is zf-5 tranny. Donor truck is auto tranny. Any info would help.Thought I'd get new injectors also.
Thewespaul
Bulverde, Texas
You only want to run new injectors on a new pump or you will potentially run into hot start issues. I can clean up your existing injectors for the time being, for the pumps you can swap them no problem. Just transfer over the hardware for the auto trans like the fipl over to the good pump. Make sure to leave the timing cover in place and pull the pump out of the gear.
RustyNail351
