some turbo questions
jonathan
sullivan In
Well I talked my wife into letting me do IP and injectors and a turbo. I would like to know how much boost the hypermax kit is capable of producing and the same for banks kit. What ever kit I choose will be new. On the fuel side it will be a moose pump with bb injectors.
I believe the waistegated Banks sidewinder is capable of more boost than the others. I think we only have a choice between the Banks and the hypermax or the ATS turbo any more. One of them is no longer supported by the maker. Typ4 aka Russ now a member here supports the hypermax or the ATS kits but contact him for info. No matter what kit you install about 12 lbs boost is the limit safely on stock head bolts. Mush more boost is super heated air because the turbo beats it up so much trying to force it into the engines so 15 lbs is a waste of energy getting you nowhere.
ntjapkes
