Rear leaf springs for f350
I use bags on my truck when I have my camper on it, I air them up to 70, really helps with ride height and handling. Springs are original from 1990.
Cainon
Smithfield
I bought the lighter weight and will be installing air bags this summer
Cainon
Smithfield
Thank you everybody for all the advice and help. I know I was very flip floppy I just wanted to make sure I was buying something good long-term also. I have definitely been convinced to go with airbags lol. Looking forward to that.
ttman4
Last Nite's Dream..
Air bags really help, not so much to carry more weight, but will stabilize the truck when carrying a load.
My rear springs are tired, and when the car trailer is connected, the rear end drops a bunch.
Pump them up to 15lbs, and levels it out.
I installed Fire Stone bags. easy to install, just don`t use Harbor Freight Drill bits. Garbage. You want to drill the hole not eventually wear the hole through the steel.
I followed this guys YT Vid on how to install them.
In about '93 I ordered & installed a set of Firestone Air Bags ($240) on my '90 LBCC Dually & run bout 10# empty & 70-80-90# loaded depending on how loaded.
Last yr I ordered set of Load Leveler 7500# from Summit ($550) & installed on my '14 HD Chev 2500.
I Am sooooo very happy with ride loaded or empty!!!!
ntjapkes
