rear drum brake removal ford 1990 f250?
huse
Norway
Thats good ;Sweet mine was so stuck that i could'nt get it loose with a 4.4 pound hammer, so i purchased a airhammer. had too work the drum for aproximately 30 min then the drum let go.. Purchasing a inexpensive airhammer was one of the best investments i've ever made! :D i find many uses for it, to drive out broken rivets is one of them, beside brake drums
Great Post, I just joined because I had the same problem and this post helped me solve the problem. I have the it's a sterling 10.25, just like the photo above from huse. After WD40 I pounded in between the lugs with my 44oz framing hammer. That did the trick. Pounding on the edges in the removal direction had no effect. Now I see lots of oil on the shoes, looks like its coming from the cylinder.
welcome to the site;Sweet
do be absolutely sure the "oil" is brake fluid and not gear oil. these axles are notorious for melting axle seals when you overheat the brakes.
Electromag
United States
I like to keep my shoes oiled well to make them last.
Well, its hard to tell.. Could be gear oil that was slung up on the brake cylinder.
Bigal093
