Orange engine warning light stays on
fraree
Inland. Australia
Since I've restarted & been running my truck after doing the injector sleeves etc plus the water pump & oilcooler the orange engine warning light has stayed illuminated once the engine is running.
Replaced the oil pressure sensor on top of the Hpop reservoir. The engine oil pressure gauge is working fine. The only code which comes up is PO237 which is a "turbo input low"
Going a towing trip in 10 days, hope to sort out what up before then !
Saw other thread first. Replace the map sensor.
Also check the icp sensor for oil. (The one to the driver side of the hpop)
fraree
Inland. Australia
Thanks 79Jasper. My truck has been converted to RH drive, so you're referring to the left side of the engine bay. I've found a connection which looks like it would fit the map sensor but I cannot remember ever seeing a map sensor (connection as shown) As this is a RH drive conversion done in Australia things are in different locations.
Can't see an air hose/pipe which would have connected either. I replaced the 2 sensors next to hpop 5k klm (2400m) ago.
What year? Yours appears to be a 99+?
Ah, yes. Complicates things a bit.
The intake plenums (under the y that is connected to the turbo) you should find a nipple and hose coming off the RH side (your driver side) about midway. Pretty much next to where the y connects.
fraree
Inland. Australia
Yes good guess '99 1/2. came out as an incomplete vehicle (cab chasis). I'll do some investigation now its morning here :Thumbs Up
fraree
Inland. Australia
Thanks for the place to start.Traced the hose off the Y :rolleyes: was pushed over the back. Scored a new job which required an imeadiate start hence a rush to finish:eek: I took months to do my injector cups etc with working away from home a few times during the job. Picking up from where you left off is always an issue. Feel like a "Goose" (Australian slang)
Another reason I use the forum so much. Thanks heaps :Thumbs Up :cheers:
fraree
Inland. Australia
Plugged it back in, the light is still on, so back to the original plan, new map sensor by the look of it. Did a code check, 603 & 237 came up, cleared them. Will see how it pans out when the new sensor arrives.
fraree
Inland. Australia
Just went & started the truck after leaving it for a while with the batteries disconnected & the "liitle green men" who hide in the electrical system must be happy once more. Orange engine light switched itself off how it should do!:Thumbs Up
Sometimes can take a bit, unless you do it with a code reader. Not a lot of them will talk the right language for these trucks.
If you are interested in any extra power, look up the hydra. I would get it from 1023 or jelibuilt.
fraree
Inland. Australia
Thanks but I already have "safe tow" tune in from my Superchips 1705 tuner. I inherited it from a family member. I know it's old but the price was right & it does the job.
Ah, I see. Were some companies still doing real tuning for those, but they may have stopped now.
ntjapkes
