Starter motor stayed engaged had to take Battry tournaments after Stafford after that heard a short and I don’t know if it’s glow plug relay or ignition switch there’s no power in the cab whatsoever
The cost of the sunlight on the firewall it will turn over but won’t start there’s no power at all to anything in the cab it might be an anti-line fuse I’m trying to find it and hopefully it is but if not there is some ignition boxes and underneath the dash I may have blown one of them
