New to me f350 what to do
Hamweld
Fort Worth Texas
Ok so about a month ago I purchased a 1989 f350 4x4 T19 Bw 1354 7.3 NA.
This thing was a brush truck in Fort Worth Texas area and has 18,000 miles on the clock. I’m needing to get this thing under power asap temporarily, this ol girl has had a rough life after fire service as a yard truck at a local buisness I’ll post some pics tomorrow.
Hamweld
Fort Worth Texas
Yes I need to get it running just enough so I can move it hasn’t ran in about 6 months. My thoughts were to put fresh batteries in it run a hose to a jerry can in the passenger seat. I know this is a bad idea but I just need to be able to move it around my property. It’s going to go under the knife late summer. Is there anything I’m missing?
Brian VT
Maine, USA
We can't say without more info.
I think I'd try to see what it'll do in it's present condition before I spent the $ on new batteries.
That's plenty enough battery. If you're just trying to move it around, make sure its got oil and coolant, attach the batteries, and hit the key. Let us know what happens after that.
hacked89
Bucks County PA
Assuming glowplug system is gonna be shot , disconnect glowplug controller, give her the ether, run a line from lift pump inlet to can and let her rip. Let us know what troubleshooting you run into and need help with.
Austin86250
idaho
I’d recommend running a fuel water separator when I bypassed mine I swapped to a 7.3 filter head (it has the fuel water separator built into the filter)
Rdnck84_03
Kansas
Where does a feller pick one of those up at?
For a factory 7.3 filter filter head I would check the salvage yards or ebay.
There are aftermarket options also. I have seen some posts with part numbers, I will try to find the thread and link it.
James
Cv axle
