New 93 turbo engine, lots of white smoke.
raydav
Apple Valley, CA
I got my 84 E350 in 1995. It came with a 460/C6. Over the next decade I swapped the C6 for an E4OD and the D70 rear for a D70 dually. In 2005 I got an 89 E350 for it's IDI. A few years ago I added a remote turbo. At that time I also had a 2001 E350 PSD. They are both 7.3, the PSD turbo seems to work well, so I had a shop build me one like the PSD. The most boost I ever saw was ten pounds. But five pounds put me up one gear on hills and the black soot was almost gone.
Prior to adding the turbo I removed the fuel filter from the engine and put a Racor on the frame.
I had bought a turbo-calibrated IP in anticipation of adding a turbo, was carrying it, and swapped it in on the road prior to adding the turbo. I replaced the injectors about a year ago. And all was well.
Recently the 89 IDI produced a large cloud of white smoke when starting cold.
I have just replaced the 89 IDI with a rebuilt 93 turbo IDI. I set the IP at the center of the slots. It produced enough white smoke to make it unusable. I advanced the IP what little I could without reforming the lines.
Now, a few seconds after starting it idles very smooth. After it warms a bit it starts instantly, and the white smoke is hardly noticeable. But run it up to maybe 2K and it billows white smoke, and runs a bit rough.
And that is where it stands. I have driven it only enough to get it on the lift, and that felt normal.
Suggestions?
Your engine really needs to be timed with a meter. Hopefully you did not remove the injection pump with the top gear housing and gear at the same time.If you did then I feel you are not gear timed correctly.
raydav
Apple Valley, CA
Yes I removed the housing with the pump. You don't get a pump, gear or housing with a rebuilt engine. And they went on gear > housing > pump.
Suggestions?
white smoke at idle and clears up instantly.....injectors.
white smoke and rpms breaking up as you throttle up....you're either off a tooth or.....your pump is done.
good luck.
Sidewinded_idi
Yucaipa ca
Yea, right after I turn a couple offset box end wrenches into tube wrenches to get at the bottom lines on the pump.
I got a new set of lines recently. Do they really need to be that stiff?
For the bottom two nuts I use a stubby craftsmen combination open/box wrench. It’s only about 3 inches in length but the open end reaches the bottom ones no problem
Macrobb
North Idaho
advance the ip gear 1 tooth(clockwise when viewed from the front of the engine).
raydav
Apple Valley, CA
I advanced the IP drive gear one tooth. I left the advance I previously got by twisting the pump.
It now seems functional. It is still on the lift, it idles smooth, and is smooth up to I am guessing about 2K; I don't have a tach. And no clouds of smoke. I hope to soon have a timing system.
When I assembled the engine, I set the IP gear on the cam gear with no gear cover or front cover. I then bolted the gear cover on, then tried to disengage the IP gear. I rattled the IP gear around in the cover but the gears stayed meshed. I then sealed to IP gear cover and did a final bolt down. I left the front cover off as long as I could and then finally installed it and the pan. I installed the IP later. That was all done on a stand.
I am confident the timing marks were properly aligned. Are the timing marks not necessarily true?
raydav
Apple Valley, CA
I got a Kent-Moore J- 33300 Tach-N-Time. I already had a serious timing light. Everything about working on a van is awkward, including timing it.
I think it is at 4 degrees BTDC at 2K RPM.
I drove it a couple miles. Under acceleration there is a lot of grey smoke, and to borrow a term from top fuel, it reminds me of cackle. But it feels OK.
At the risk of starting another G-BB discussion, what is this weeks choice for injectors? And trusted source please.
And I posted a few more pics.
https://goo.gl/photos/LJNV4esgmYmSzKdL8
raydav
Apple Valley, CA
I had a discussion with an IP and injector re-builder. Like most others he said white smoke indicates the IP should be advanced. So I advanced it and the rattle got worse. So I retarded it and the rattle is either gone or almost so. I have said that if it was a gas engine I would think it had too much spark advance.
It idles and runs smooth, never a miss, and warm starts instantly. But the white/grey smoke is still antisocial.
I have not yet got on it hard up hill to check max performance.
All the fuel related stuff from the old engine went on the new. Could a fresh engine make obvious smoke that was only marginal with the old engine?
raydav
Apple Valley, CA
I don’t see a reason why the old engine would mask that
The question was more like could the higher compression of a fresh engine produce more smoke?
I have kinda got it to where the old was; it produces white/grey smoke with a heavy foot at low RPM, and the sound during that time tends toward what I call rattle.
ntjapkes
